> try the attached. I don't know who wrote it but it works.
Looks like James Atkin back in 2000.
I was looking for something like an inverse intersection. PHP gets close. I thought matlab would have something but I guess not. -SHAWN-
--- You are currently subscribed to vrf as: rsb@soco.agilent.com To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><TITLE>Driver needed for 53152A</TITLE><META http-equiv=Content-Type content="text/html; charset=us-ascii"><META content="MSHTML 6.00.5296.0" name=GENERATOR></HEAD><BODY><DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=406572419-17022006>Agilent never wrote one, and this beast is different enough that I can't even recommend one to adapt. I expect you probably already knew that. Not even anything over on the Dark Lord's site </SPAN></FONT></DIV><DIV> </DIV><!-- Converted from text/rtf format --><P align=left><SPAN lang=en-us><FONT face=Arial size=2>Jay Nemeth-Johannes</FONT></SPAN> <BR><FONT face=Arial size=2>Smart Sensor Systems</FONT> <BR><SPAN lang=en-us><FONT face=Arial size=2>720 SW 14th Street</FONT></SPAN> <BR><SPAN lang=en-us><FONT face=Arial size=2>Loveland, Colorado 80537</FONT></SPAN> <BR><SPAN lang=en-us><FONT face=Arial>(970) 663-0006 </FONT></SPAN> <BR><SPAN lang=en-us><FONT face=Arial size=2><A href="http://www.smartsensorsystems.com/">www.SmartSensorSystems.com</A></FONT></SPAN> </P><DIV> </DIV><BR><BLOCKQUOTE style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #0000ff 2px solid; MARGIN-RIGHT: 0px"> <DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left> <HR tabIndex=-1> <FONT face=Tahoma size=2><B>From:</B> Andersen, Dave-P26278 [mailto:Dave.Andersen@gdc4s.com] <BR><B>Sent:</B> Friday, February 17, 2006 9:03 AM<BR><B>To:</B> VRF<BR><B>Subject:</B> [vrf] Driver needed for 53152A<BR></FONT><BR></DIV> <DIV></DIV><!-- Converted from text/rtf format --> <P><FONT face=Arial size=2>All,</FONT> </P> <P><FONT face=Arial size=2>Anyone know where I can find a driver for the</FONT><FONT face=Arial size=2><B> 53152A CW Microwave Frequency Counter, 46 GHz?</B></FONT> </P><BR> <P><FONT face=Arial size=2>Dave Andersen</FONT> <BR><FONT face=Arial size=2>Software Engineer</FONT> <BR><FONT face=Arial size=2>Space & National Systems Division</FONT> <BR><FONT face=Arial size=2>General Dynamics C4 Systems</FONT> </P> <P><FONT face=Arial size=2>email: Dave.Andersen@gdc4s.com</FONT> <BR><FONT face=Arial size=2>phone:(480) 441-8764</FONT> <BR><FONT face=Arial size=2>fax: (480) 441-8500</FONT> <BR><FONT face=Arial size=2>numeric pager: 1-877-542-5574</FONT> <BR><FONT face=Arial size=2>text pager via email: 4802448875@vtext.com</FONT> </P><BR>--- <BR>You are currently subscribed to vrf as: jay.johannes@completetest.com <BR>To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". <BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". <BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". <BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". </BLOCKQUOTE><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email request to "join-vrf@lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></HTML>
Hello from Gavin Cleary,                     I am performing a voltage sweep, and from the voltage sweep I am trying to determine the breakdown voltage. I have an array of current and voltage. I need the program to define the closest voltage range over 1uA, as the breakdown voltage, see below  V             I -28.5       1.95e-7 -28.75     2.233e-6 -29         4.3835e-6  I then need the program to display the voltage so far I have been trying to implement a for loop into a formula box but this creates an error, and using a Matlab script will not let me define the output of the array over the 1uA values. If you have any suggestions it would be most appreciated.  Regards             Gavin
The HpVEE version I'm using is 4.0 (age of the rock)and it does not have excel97a.vee, Excel97b.vee, and Excel97a UFunction Lib.vee files. If someone could send me I'll be grateful! Thanks Jef
--- Jefferson Oliveira <jefrol76@yahoo.com.br> escreveu:
> Hi Hammer, > > Thank you for the sugestion. > I uesed (Select Terminal by Component) and after > that > (To/From DDE) to launch MS Excel. However, Im not > sure if the MS Excel directory is in my PATH and I > do > not no where can I find that PATH (autoexec.bat > file?) > It is not working! > > Reagards > > > > > --- Les Hammer <Les.Hammer@CompleteTest.com> > escreveu: > > > > Im using a Dynamic Signal Analiser Hp35665A, > > HPVEE 6.0 > > OK > > > > > and GPIB National Instruments card board > > (OK, but not relevant) > > > > > to mesure electrochemical signs. The > comunications > > between > > > hardware and software are ok. Set-up straight! > > > I have some doubts about how to get the data > from > > the panel driver > > Right click on the right side of the panel. It > > brings up a menu > > which includes "Add Terminal -> Data Output." > Click > > that, then select > > the component you want (if you know the name.) If > > you don't know the > > name, use "Select Terminal by Component", then > click > > on the widget > > you want to output. Wire either of these to the > > Excel file. > > > > > and save it as a file (EXEL e.g.). > > > > ~Les Hammer > > VP of Engineering > > Smart Sensor Systems > > 720 14th Street SW > > Loveland, CO. 80537-6349 > > Les.Hammer@SmartSensorSystems.com > > Les.Hammer@CompleteTest.com > > > > > > > > > > > > > > > > _______________________________________________________ > > Yahoo! doce lar. Faa do Yahoo! sua homepage. > http://br.yahoo.com/homepageset.html > > > --- > You are currently subscribed to vrf as: > jefrol76@yahoo.com.br > To subscribe send a blank email request to > "join-vrf@lists.it.agilent.com". > To unsubscribe send a blank email to > "leave-vrf@it.lists.it.agilent.com". > To send messages to this mailing list, email > "vrf@agilent.com". > If you need help with the mailing list send a > message to "owner-vrf@it.lists.it.agilent.com". > Search the "unofficial vrf archive" at > "www.oswegosw.com/vrf_archive/". >
_______________________________________________________ Yahoo! Acesso Grtis - Internet rpida e grtis. Instale o discador agora! http://br.acesso.yahoo.com
I have a array of numbers which may contain the same number (see attachment).
I would like to know if someone has any idea how I can remove the same value from the array,
so final array should be without these numbers.
Â
Â
Regards
Arie Fainbrun
Â
Â
Regards
Arie Fainbrun
>I have a array of numbers which may contain the same number (see >attachment). >I would like to know if someone has any idea how I can remove the same value >from the array, >so final array should be without these numbers.
This is one that will almost certainly include a loop or two. One simple method would be to take the list of duplicates that you already have then write a little loop that uses the COMPARATOR to remove the offending values
( i.e. for each value you want to remove from the loop, feed the array through a comparator with the comparison being a==b and ref value being the value to remove. That way the "failures" list is the array without this value )
There's lost of variations.
Stan
-------------------------------------------------------------------------- Stan Bischof Agilent Technologies 707-577-3994 stan_bischof@agilent.com --------------------------------------------------------------------------
Stan
Stan
Stan
>I have a array of numbers which may contain the same number (see >attachment). >I would like to know if someone has any idea how I can remove the same >value from the array, so final array should be without these numbers.
Stan
--- To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
Stan
Agilent never wrote one, and this beast is different enough that I can't even recommend one to adapt. I expect you probably already knew that. Not even anything over on the Dark Lord's site Â
Jay Nemeth-Johannes Smart Sensor Systems 720 SW 14th Street Loveland, Colorado 80537 (970) 663-0006 HYPERLINK "http://www.smartsensorsystems.com/"www.SmartSensorSystems.com
Â
 _____ Â
From: Andersen, Dave-P26278 [mailto:Dave.Andersen@gdc4s.com] Sent: Friday, February 17, 2006 9:03 AM To: VRF Subject: [vrf] Driver needed for 53152A
All,
Anyone know where I can find a driver for the 53152A CW Microwave Frequency Counter, 46 GHz?
Dave Andersen Software Engineer Space & National Systems Division General Dynamics C4 Systems
--- You are currently subscribed to vrf as: jay.johannes@completetest.com To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
Â
 _____ Â
All,
> I think there is a problem with your > solution - it does not detect duplicates > which do not occur in sequence!
That's why the sort is in there. -SHAWN-
> I think there is a problem with your > solution - it does not detect duplicates which do not occur in > sequence!
-SHAWN-
