vrf Question regarding VEE PRO 6.0 and Matlab
Question asked by jvera on Jul 31, 2003
Does this trick also work for toolboxes other than the Signal Processing that is already integrated in VEE 6.x?
My interest is to have access to Communications Toolbox from VEE.
Regards
Juan
-----Mensaje original-----
De: Stan Bischof (Richard S) [mailto:rsb@soco.agilent.com]
Enviado el: mircoles, 14 de mayo de 2003 16:18
Para: VEE vrf
CC: vrf@it.lists.it.agilent.com
Asunto: [vrf] Re: Question regarding VEE PRO 6.0 and Matlab
"Martino Rosin" <MartinoRosin@calearo.com> wrote:
> In my company we have licenses of both Matlab and VEE PRO 6.0 and we use
> them for data acquisition and processing.
> We are not able to register the Matlab engine in VEE, such that we can use
> the full version of Matlab inside VEE. Also (and probably, consequently),
> we are not able to use our own written m-files inside the Matlab script
> calls in VEE (as in Matlab).
> Do you know any way to do that ?
We routinely use the full Matlab within VEE, but there are details
to watch out for.
(1) make sure you have the correct version of Matlab vs VEE since
    the interface changes with versions
   VEE 6.01 needs matlab 5.x
   VEE 6.1 needs matlab 6.x
(2) install VEE and Matlab then find the Matlab executable and
     register the interface using
    matlab.exe   /regserver
that should do the trick
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
You are currently subscribed to vrf as: jvera@indra.es
Este correo electrnico y, en su caso, cualquier fichero anexo al mismo, contiene informacin de carcter confidencial exclusivamente dirigida a su destinatario o destinatarios. Queda prohibida su divulgacin, copia o distribucin a terceros sin la previa autorizacin escrita de Indra. En el caso de haber recibido este correo electrnico por error, se ruega notificar inmediatamente esta circunstancia mediante reenvo a la direccin electrnica del remitente.
The information in this e-mail and in any attachments is confidential and solely for the attention and use of the named addressee(s). You are hereby notified that any dissemination, distribution or copy of this communication is prohibited without the prior written consent of Indra. If you have received this communication in error, please, notify the sender by reply e-mail
