> but have you ever hear of HT-Basic.
> It is a basic programming and it use to be from HP.
Gulp, hack, cough, sputter.
Not quite. HP had Rocky Moutain Basic, which ran on HP Workstations.
Another company ripped off the design and made HT-Basic. HP made no attempt
(that I know of) to defend this, because at the time it had no interrest in
using the PC for instrument control.
That's not to say that HT-Basic isn't good. It just didn't "use to be from
HP."
Les Hammer
examples of how to do this using SocketWrench on this list, but they all
dealt with ASCII strings. I need to send data that is not ASCII strings. I
have tried SocketWrench using the ReadBytes method, but I can't seem to
figure out how to read back the data array. I initialize a unsigned integer
array and pass it to the method, but when I read it back after the method
completes, the buffer has not changed.
I have also tried using .Net to accomplish this task, but I run into the
same problem using the ReadFrom method.
Can anyone help me out? I am running Vee Pro 7.
Brad Avants
