Shawn,
The problem doesn't seem to be just that; In my case, savePanelImage works with color
depth set to 256 (default) or 65536, but does not work for any other settings including
down to 8 or 16.
-Vinod
--- Shawn wrote:
Oops! Yes I see. Well, for capturing bitmaps software is supposed to check for valid
color depth (bits per pixel) *before* calling CreateCompatibleBitmap, but it looks like
VEE is just passing the given value through without checking first.
Exactly what a valid value is depends on your video hardware/driver,...
--- Vinod <papineni_vinod@yahoo.com> wrote:
> Hello,
> files and .bmp files (with default 256 colors).
> Changing color depth to anything other than 256 causes error
> Example: savePanelImage("myFunction","C:\Temp\Test.bmp", 512)
> Notice this problem both in VEE 6.01 and 7.5. Has anyone seen
> this?
> -Vinod
__________________________________________
Yahoo! DSL Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
down to 8 or 16.
-Vinod
> Hello,
> this?
> -Vinod
dsl.yahoo.com
Is there a way to programically fix this from within VEE?
I have tried the using the timeout to remove the box and immediately replace it with another copy, however that didn't work.
The only thing that I have seen work is moving the mouse or answering the box.
Any ideas?
Jon Griggs
mailto:jgriggs@crownintl.com
Test Engineer
Crown International
1718 West Mishawaka Road
Elkhart, IN 46517
