Yes Shawn,
But I could have text values within my array!! I do not know in advance what
is in the array. I could write each cell one at a time by going through
every element of the array, but then I lose the speed advantage of just
writing an array.
Simon
Sent: 11 January 2006 16:29
To: Simon Parfitt; 'VRF'
Subject: RE: [vrf] VXL (excel) problem
> Yes it is correct
Mkay. I'm beginning to understand. It doesn't work here either. My theory so
far is because data are entered as text number formats have no effect, so
the problem is converting the values to numbers before formatting.
-SHAWN-
writing an array.
Simon
> Yes it is correct
-SHAWN-
