Take a look at VM1602 at www.vxitech.com
From: Alex.Barrett@raytheon.co.uk [mailto:Alex.Barrett@raytheon.co.uk]
Sent: Wednesday, January 26, 2005 12:41 PM
To: VRF
Subject: [vrf] exact real timing on a scope (or something)
Hi vrf... a weird test related problem this...
I need to find the actual time that a pulse goes high on a scope.
(eg, the pulse went high at 10:24.32pm)
the propogation delay between scope, gpib, vee and the PC would be too
long, so essentially I need to know if anyone knows of a scope (or any
other piece of equipment) which will log the actual time of a pulse
occuring..
Any suggestions wouldbe gratefully received...
Al.
You are currently subscribed to vrf as: omer.akbas@arcelik.com
_____________________________________________________________________________________________________________________________________________
Bu e-posta mesaji kisiye ozel olup, gizli bilgiler iceriyor olabilir. Eger bu e-posta mesaji size yanlislikla ulasmissa, icerigini hic bir sekilde kullanmayiniz ve ekli dosyalari acmayiniz. Bu durumda lutfen e-posta mesajini kullaniciya hemen geri gonderiniz ve tum kopyalarini mesaj kutunuzdan siliniz. Bu e-posta mesaji, hic bir sekilde, herhangi bir amac icin cogaltilamaz, yayinlanamaz ve para karsiligi satilamaz. Bu e-posta mesaji viruslere karsi anti-virus sistemleri tarafindan taranmistir. Ancak yollayici, bu e-posta mesajinin - virus koruma sistemleri ile kontrol ediliyor olsa bile - virus icermedigini garanti etmez ve meydana gelebilecek zararlardan dogacak hicbir sorumlulugu kabul etmez.
This message is intended solely for the use of the individual or entity to whom it is addressed , and may contain confidential information. If you are not the intended recipient of this message or you receive this mail in error, you should refrain from making any use of the contents and from opening any attachment. In that case, please notify the sender immediately and return the message to the sender, then, delete and destroy all copies. This e-mail message, can not be copied, published or sold for any reason. This e-mail message has been swept by anti-virus systems for the presence of computer viruses. In doing so, however, sender cannot warrant that virus or other forms of data corruption may not be present and do not take any responsibility in any occurrence.
To: VRF
occuring..
Al.
There are several solutions I could think of depending on your
requirements including timing resolution and accuracy such as
data acqusition card constantly running and monitoring the level
data acquisition unit ( such as the Agilent 34970 ) which time-stamps data
as it is acquired
Mike Watts
Michael Watts, Consultant PO Box 92
on the web: www.PreciselySo.Co.UK Exeter,Devon
e-mail: MJWC@PreciselySo.Co.UK England
tel: +44 7714 339 729 EX4 2YY
