Well, it was working until I tried use the serial port. If I'm just using GPIB everything is fine. When I tried a program that needs the serial port I get a SICL error message--"sicl32.dll not found."
Â
Is there a way to fix this? Can I install SICL without messing up all the National stuff?
Â
Bill
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Tuesday, January 10, 2006 7:04 AM
To: VRF
Subject: RE: [vrf] VEE with Nat'l VISA
All,
I installed VEE 7.0 runtime on my NI system yesterday and it worked. No problems at all.
Bill
> From: Baranski, Detlef [mailto:Detlef.Baranski@pilkington.de]
> Sent: Tuesday, January 10, 2006 6:54 AM
> To: 'Drago, William @NARDAEAST'; VRF
> Subject: AW: [vrf] VEE with Nat'l VISA
> It not that easy , sorry.
> Read the Manual. There are different things to take care
> dependent on the
> VEE Version you have.
> Since Vee 7 you need NI Visa lib 3 or higher , otherwise it
> is not working.
> With Iolib 14.1 and VEE 7.5 it should work without any big
> problems if Nilib
> is installed first. But there were some troubles also....
> So let us know if your attempt work.
> Best regards,
> detlef
> -----Ursprüngliche Nachricht-----
> Von: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
> Gesendet: Freitag, 6. Januar 2006 16:38
> An: VRF
> Betreff: RE: [vrf] VEE with Nat'l VISA
> Thanks, I'll give it a try.
> Â
> Bill
> From: BOCKSTAL,DANIEL (A-Belgium,ex1)
> [mailto:daniel_bockstal@agilent.com]
> Sent: Friday, January 06, 2006 8:45 AM
> To: VRF
> Hello Drago,
> VEE will play nicely with NI's VISA, no problem. You can have
> a side by side
> installation (NI VISA + Agilent VISA) on the same computer,
> but this is only
> required if you mix Agilent's and NI's hardware (an Agilent
> GPIB card and an
> NI GPIB card in the same PC)
> Â Best regards
> Daniel Bockstal
> Sent: Friday, January 06, 2006 2:23 PM
> To: VRF
> Subject: [vrf] VEE with Nat'l VISA
> All,
> Â
> I have a test system running LabWindows/CVI and TestStand. I want to
> install VEE runtime so I can use the equipment in that test
> system with some
> of my VEE programs.
> Â
> Will VEE play nice with the Nat'l VISA or does it need it's
> own? And, if it
> does need it's own, can the two VISAs co-exist?
> Â
> Thanks,
> Bill
> You are currently subscribed to vrf as: daniel_bockstal@agilent.com
> To subscribe send a blank email to
> "join-vrf@it.lists.it.agilent.com".
> Search the "unofficial vrf archive" at
> "www.oswegosw.com/vrf_archive/".
> You are currently subscribed to vrf as: William.Drago@l-3com.com
> This e-mail and subsequent attachments may contain
> information which is
> proprietary to L-3 Communications Corporation. The contents
> shall not be
> disclosed, copied, distributed or used unless authorized by L-3
> Communications Narda - East.
> You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
 This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.
To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".
Â
Â
Bill
To: VRF
All,
Bill
> dependent on the
> is not working.
> problems if Nilib
> Best regards,
> detlef
> An: VRF
> Â
> Bill
> To: VRF
> Hello Drago,
> a side by side
> but this is only
> GPIB card and an
> Â Best regards
> Daniel Bockstal
> To: VRF
> All,
> Â
> system with some
> of my VEE programs.
> Â
> own? And, if it
> Â
> Thanks,
> Bill
> shall not be
