Oh MY! They have support out the rear.
Take a look at the Active X Example Files at
http://www.tharo.com/download.htm#samples
They're in VB6 but they're simple. Probably all you'll have to do is find a
ProgID. And that only if you want to blow off the control.
-SHAWN-
-SHAWN-
I have little experience with activeX, so am looking for some help. I have
a program that writes data to be printed to a text file. Then I use an
execute program box to open the printing software "EasyLable", which is set
up to automatically open the label format with the data that I need to
print. What I would like to do next is use ActiveX to automatically print
the label. Has anyone used this software, and have a print example?
Best Regards,
Tom Daniels
Sr. Test Engineer
The Morey Corporation
100 Morey Drive
Woodridge, IL 60517
T: (630) 754-2256
F: (630) 754-2656
tdaniels@moreycorp.com
