vrf Text To Speech (was: Playing WAV or other sound files w ith VEE)
Question asked by warren.pickles on Feb 23, 2005
I still can't get SpeakToMe.vee working, even with an OK button.  No errors
or anything, just no sound.  Giving up on it for now.
Incidentally, while playing around trying to find another way of doing
text-to-speech, under "ActiveX Automation References" I found "Microsoft
Speech Object Library".  Sounds promising, but I've no idea how to use it
and can't find any docs on the MS website.  Anyone got any experience /
examples with this?
Warren
Sent: 23 February 2005 10:32
To: VRF
Subject: RE: [vrf] Playing WAV or other sound files with VEE
It didn't run on my laptop either until I added a "confirm ok" button after
the "speak" formula.  I guess the confirm ok button gives it time to work
before vee ends the process (ie it runs until you press the ok button).
nick
From: Les Hammer [mailto:Les.Hammer@CompleteTest.com]
Sent: 22 February 2005 23:10
To: VRF
> And so here is the example. You need Direct Text-to-Speech installed.
> On the ActiveX Control References... menu, check Microsoft Direct
Text-to-Speech.
> Then select Device->ActiveX Controls-> choose the DirectSS control and
plop
> it on your workspace. Then just call Speak (ok, so I thought it was
"Say").
All that is there, but it doesn't make any sound when I click run.
Les
You are currently subscribed to vrf as: Nick@genesysibs.com To subscribe
send a blank email to "join-vrf@it.lists.it.agilent.com".
You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com
