Good morning Alex, I am using the PCI-CDa high speed digital IO card
from EDT for LVDS use. I am currently using it under Linux but they
have a very good API for Linux and I believe their Windows API is
essentially identical. Their support is unbelievable and I have no doubt
that they can help you get up and running very quickly. When you call
the help line you get direct access the the engineers that designed the
board and who wrote the software for it. I plan on trying the card with
VEE sometime in the near future.
http://www.edt.com
EDT Incorporated
1100 N.W. Compton Drive
Suite 306
Beaverton, OR 97006
503 690 1234 Voice
503 690 1243 FAX
http://www.edt.com
EDT Incorporated
Suite 306
Beaverton, OR 97006
503 690 1234 Voice
503 690 1243 FAX
low voltage transducers and sensors. I use a supplier called CyberResearch
at cyberresearch.com, they are a US based company and I do not know if the
will ship to the UK, but if you take a look at their selection you may find
something similar close to home. I've used there 16 channel thermocouple
differential input board with cold junction compensation screw terminal
connection on a 5 foot cord and an 8 channel differential input board, also
with external connection pod. You will need to purchase CYDAS UDR which is
the "universal drivers" for the cards so they work with Vee.
Good luck
Doug
From: Alex.Barrett@raytheon.co.uk [mailto:Alex.Barrett@raytheon.co.uk]
Sent: Friday, February 18, 2005 4:45 AM
To: VRF
Subject: [vrf] reading LVDS
Hi vrf,
This is a bit of an urgent one...
has anyone used VEE to read an LVDS signal??
If anyone has done this, any recommended LVDS compatible I/O card (with vee
drivers, or easy to use DLL's) would be a huuuge help!!!
Many thanks to anyone who can help...
(LVDS is Low Voltage differential signal)
You are currently subscribed to vrf as: decote@verizon.net
