Graeme Hilton <GHilton@slb.com> wrote:
> I never understood how "replace" worked. It never seemed to do what I
> expected
> it to do.
Let's say you have an object "A" that's hooked up somewhere
in your program. And you like to replace that object with a different
one- "B". But there's all sorts of connections that you don't
want to redo.
instantiate "B" and set it up the way you want- ideally matching
the pinouts of "A" so that it will drop in cleanly.
bring up "A"'s menu and choose "replace"
the cursor changes to a crosshair
click on "B" and drag it into place
Note that "A" ends up in your cut buffer, so that if you
immediatley do a "past" then you'll have A sitting disconnected.
Also VEE will do its best to hook things up if the pinouts
of "A" and "B" don't match
very useful at times.
Stan
> expected
> it to do.
want to redo.
Stan
program.
> And you like to replace that object with a different one- "B"....
OK, tht will get you part way there. But what if I still want A connected
to some things. I just want to insert B (or, gasp, discover a programming
error <in someone else's code
to be connected to B instead of A. The other GPL makes it easy. (right
there in normal mode, don't have to look for a "replace" command.) With VEE
it isn't.
--Les
