Â
Hi Bill,
Â
Callable VEE is available in Runtime - I think the only loss in functionality is that you do not get debug mode. A couple of other things:
Â
1) Watch for the separate vee.io config files
2) You will see this in Dev & Runtime: in my experience, when you call a function it kind of does a pre-run. So, say you have called FuncA which sets up some variables, then call FuncB which uses these variables. You will get problems because as far as FuncB is concerned those variables may be declared but will not have been initialized. The way I got around this was to uncheck the 'Delete Variables at Prerun' in the VEE Properties (available for Dev and Runtime independently)
Â
Cheers
Â
Andy
Â
Â
 _____ Â
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Thursday, February 16, 2006 12:37 PM
To: VRF
Subject: [vrf] Callable VEE in Runtime only install
All,
Â
Is callable VEE available in the runtime only VEE install or do I have to install the development version?
Â
Bill
Â
To subscribe send a blank email request to "join-vrf@lists.it.agilent.com".
Hi Bill,
Â
Â
Â
Cheers
Â
Andy
Â
Â
 _____ Â
To: VRF
All,
Â
Â
Bill
Â
Well the type library is certainly there. I imagine the whole thing is. It's
implementation is probably in the service manager (installed with run time
also).
-SHAWN-
