Hi;
I was under the impression that VEE 7.5 IS Win 98 compatible with the addition of a DLL (?) to handle DDE exchange between window apps. I'm told, although I have not yet checked, that this add on is available from Agilent. Is this correct?
Tx
Mark
Sent: Monday, February 27, 2006 1:36 AM
To: VRF
Subject: Re: [vrf] VEE runtime on Win98SE
Hello!
Your discovery is indeed correct. It is because of the usage of DotNet controls in 7.5 and later versions that Win98SE is no longer a valid version. Indeed the current release of the IOLIBs only run on XP and 2000.
Gregg C Levine gregg.drwho8@gmail.com
"This signature was once found posting rude messages in English in the Moscow subway."
On 2/27/06, Lapworth, David <David.Lapworth@airservicesaustralia.com>
wrote:
> Is it possible to get VEE 7.51 runtime to install on a Windows 98SE
> machine? The handbook says that it is compatible with Win98SE, WinME,
> Win2000, WinXP etc. but the actual installation program ends with a
> message that it is only compatible with Win2000 or WinXP.
> TIA
> David
> You are currently subscribed to vrf as: gregg.drwho8@gmail.com To
> subscribe send a blank email request to
"join-vrf@lists.it.agilent.com".
> Search the "unofficial vrf archive" at
"www.oswegosw.com/vrf_archive/".
You are currently subscribed to vrf as: mcarangi@gulton.com To subscribe send a blank email request to "join-vrf@lists.it.agilent.com".
Tx
Mark
To: VRF
Hello!
> TIA
> David
<font size=2 face="sans-serif">Hi Vrf,</font>
<font size=2 face="sans-serif"> I am playing with the combo box feature that's in Vee 7.5. Works well</font>
<font size=2 face="sans-serif">but does anybody know how to produce a multi column combo box.</font>
<font size=2 face="sans-serif">Any help would be appreciated.</font>
<font size=2 face="sans-serif">believe it may use the command .ListColumns.Add("State Item1").</font>
<font size=2 face="sans-serif">But when you look at the operation properties for the combo box, there is no ListColumns command.</font>
<font size=2 face="sans-serif">Thanks in advance</font>
<font size=2 face="sans-serif">Best Regards</font>
<font size=2 face="sans-serif">Gavin Candy.</font>
<font size=2 face="sans-serif">Quality Engineer.</font>
<font size=2 face="sans-serif">BHC Components Ltd</font>
<font size=2 face="sans-serif">20-21 Cumberland Drive</font>
<font size=2 face="sans-serif">GranbyIndustrial Estate</font>
<font size=2 face="sans-serif">Weymouth</font>
<font size=2 face="sans-serif">DT4 9TE</font>
<font size=2 face="sans-serif">England</font>
<font size=2 face="sans-serif">Tel: ++44 1305 830734</font>
<font size=2 face="sans-serif">Fax: ++44 1305 760670</font>
<font size=2 face="sans-serif">Email: gavin.candy@bhc.co.uk</font>
<font size=2 face="sans-serif">website: http://www.bhc.co.uk</font>
---You are currently subscribed to vrf as: rsb@soco.agilent.comTo subscribe send a blank email request to "join-vrf@lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
