This occurs at my computers also without vee. It's a shame....
Seems to have something to do with Virus Protection program and other
services which communicate via LAN.
Without lan these troubles are less.
One other thing was the setup of IT-experts.
I do have a laptop with 1 GB memory, and their set up was fixed to 3 GB Swap
file. That leads to seconds of non reactings....
Changing to "swap controls by system" helps a lot.
Best regards,
detlef
Von: SPANGENBERG,SASCHA (A-Scotland,ex1) [mailto:sspangenberg@agilent.com]
Gesendet: Montag, 27. Juni 2005 11:46
An: VRF
Betreff: RE: [vrf] Hotkey Troubles
CPU load is very low, memory should be no problem either though at times
it
does access the swap file more frequently..
Sascha.
> -----Original Message-----
> From: Mike Groves [mailto:mike@grovesnet.org]
> Sent: 27 June 2005 10:17
> To: PDL-LISTS,VRF (A-Lists,unix1)
> Subject: RE: [vrf] Hotkey Troubles
> Sascha,
> What's your processor utilization during editing?
> Is there sufficiant RAM to keep it from paging?
> Just a couple of thoughts.
> Mike Groves
> From: SPANGENBERG,SASCHA (A-Scotland,ex1)
> Sent: Monday, June 27, 2005 2:28 AM
> To: VRF
> Subject: [vrf] Hotkey Troubles
> Hi All -
> does anyone have problems with hotkeys not working properly
> in vee 7.0?
> I seem to struggle quite a bit with hotkeys having to press
> them several
> times before they works.
> This happens occasionally but consistently.
> Often Ctrl-C needs to be pressed several times before Ctrl-V
> pastes the
> object that was selected during Ctrl-C.
> More problematic than a copy not working was the case when
> Ctrl-A/Ctrl-D
> to add/delete terminals misbehaved a few times which gave me terminals
> in a user function other than the one I was editing at the time!!!
> I know this sounds strange..
> I tried to add a terminal to a object within a user function.
> The object
> was selected and the mouse was over the input
> terminal area of the object but nothing happened. So I hit it Ctrl-A
> several times until I re-selected the object and eventually got the
> terminal. I ran the program and got an error about unconnected
> terminals.
> I jump to the location and found that I had added several terminals to
> another UF, the window of which was behind the UF that I was
> editing at
> the time. So it seems there might be something going on with the mouse
> focus not being updated properly? Wild guess...
> This problem occurs on two independent, non-identical computers but I
> don't exclude the possibility of this being caused by some third party
> software that is installed on both machines... (It occurs to me that a
> key logger could maybe cause such
> a behaviour but I have tested both systems thoroughly and
> they both pass
> As-Aware, SpyBot etc)
> Either way I thought I might see if anyone else is having similar
> problems..
> Regards,
> Sascha
> You are currently subscribed to vrf as: mike@grovesnet.org
> You are currently subscribed to vrf as: sspangenberg@agilent.com
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
Best regards,
detlef
An: VRF
it
Sascha.
> Sascha,
> Mike Groves
> To: VRF
> Hi All -
> in vee 7.0?
> them several
> pastes the
> Ctrl-A/Ctrl-D
> The object
> terminals.
> editing at
> they both pass
> problems..
> Regards,
> Sascha
