Shawn Fessenden wrote the following on 22/11/2005 19:10:
>> I was thinking of marking the last
>> processed line, but if I can not
>> jump to the "mark", then it does
>> not make sense.
> No problem at all. Simply save the byte offset of the last processed cr/lf.
> When you reopen the file, simply skip ahead that many bytes.
I find that reading the file into the NULL variable speeds things up a little,
especially on slower PCs.
Read Text NULL Char ARRAY 1D Size: A
where A is the offset.
Then carry on reading as normal.
Graeme Hilton
R&D Engineer
Schlumberger Sensa
>> not make sense.
Graeme Hilton
R&D Engineer
Schlumberger Sensa
