AW: vrf 5V 3.3V Level shifting ..
Question asked by bertram.koelbli on Aug 10, 2005
Best technical solution would be to use six octal buffers 74AHC244 and
supply them with 3.3V.
Bertram
Von: Alex.Barrett@raytheon.co.uk [mailto:Alex.Barrett@raytheon.co.uk]
Gesendet: Dienstag, 9. August 2005 09:15
An: VRF
Betreff: [vrf] 5V > 3.3V Level shifting ..
Hi vrf,  - not strictly a VEE question I know, but desperately need some
help!
The Test System I'm currently getting to work (note term of phrase that
we've already built it!) needs to convert 48 channels of 5V logic to 3.3V
logic (ok, so I bought a 5V card and programmed it all up). Has any of you
guys (or gals) had to do this? - and what would you use?? - I'm looking for
if anyone has a test equipnment 'buy off the shelf quickly' solution, rather
than using individual devices.
Please help if you can, and apologies for this slight mis-use of the vrf...
Alex.
               (Embedded image moved to
               file: pic29213.gif)
(Embedded     Alex Barrett
image moved   Test Development Engineer
to file:      Raytheon Systems Limited
pic07627.gif) The Pinnacles
               Harlow
               Essex CM19 5BB
               United Kingdom
               (  +44 (0) 1279 407768
               (  +44 (0) 1279 407620 fax
You are currently subscribed to vrf as: bertram.koelbli@honeywell.com To
subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
