<font size=2 face="sans-serif">The printing does leave much to be desired. And when your IT department controls the printers, it becomes a choreto ensure that your landscape mode print out always comes out the rightway the first time it prints after opening your code. Since you donot control the driver, you cannot control the default orientation. </font>
<font size=2 face="sans-serif">I have given up on trying the get thescreen perfect and then printing it. It is especially bad when yourperfectly laid out table suddenly needs a new row of data right in themiddle.</font>
<font size=2 face="sans-serif">The answer for me was to use Word bycreating a Word document that acts as a template. In the table, Iplace tags of the format {[tagname]} and then do a search and replace foreach tag. It is all right out of the VEE tutorials but I do not rememberif they were the stock tutorials or something I got from the Agilent website. Add in some advice that you all provided and the thing worksjust fine. I have a company logo on the top and changes in formator content are a breeze.</font>
<font size=2 face="sans-serif">I do create a bitmap of a VEE graphwhich is generated in its own userfunction panel and paste that on to thebottom of my report. I have not tried all of this if VEE 7 yet.</font>
<font size=2 face="sans-serif">Paul</font>
Paul Sylvester
Business Line Ultrasound
Philips Medical Systems
3000 Minuteman Road
Andover, MA 01810
978-659-4836
paul.sylvester@philips.com</font>
<table width=100%><tr valign=top><td><td>
<font size=1 face="sans-serif"><b>"Schlieker, Reiner" |reiner.schlieker@siemens.com></b></font><p><font size=1 face="sans-serif">03/29/2005 11:05 AM</font>
<font size=1 face="sans-serif">Please respond to "Schlieker, Reiner"</font><td><font size=1 face="Arial"> </font>
<font size=1 face="sans-serif"> To: VRF |vrf@agilent.com></font>
<font size=1 face="sans-serif"> cc: (bcc: Paul Sylvester/ANR/MS/PHILIPS)</font>
<font size=1 face="sans-serif"> Subject: RE: [vrf] VEE 7 Print Screen Problem</font><p><font size=1 face="sans-serif"> Classification: </font>
</table>
<font size=2 color=blue face="Arial">Probably, no one else reportedthe problem because they know that printing from VEE sucks big time andso they don't expect any better. Anyone that really needs to printsomething presentable uses ActiveX. I personnally think that VEEitself should have better printing capabilities - ActiveX (or .NET) isfine for fancier stuff, but VEE should be able to print out a panel youcreate, and scale it appropriately for printing. (Scale to fit)</font>
<font size=3> </font>
<font size=2 color=blue face="Arial">Hope that did come off soundingtoo harsh; I'd just like to see this improved. I love VEE, honest!</font>
<font size=2 color=blue face="Arial">Reiner</font>
<font size=2 face="Tahoma">-----Original Message-----<b>
From:</b> kirk_reed@agilent.com [mailto:kirk_reed@agilent.com]<b>
Sent:</b> Tuesday, March 29, 2005 8:36 AM<b>
To:</b> VRF<b>
Subject:</b> RE: [vrf] VEE 7 Print Screen Problem
</font>
<font size=2 color=#000080 face="Arial">I too also found this bug. There is also another bug with the Print Screen function in Vee 7. Sizing the print with a percentage from within the Default PreferencesPrinting tab has NO EFFECT. It worked in Vee 6.2, but not in Vee7. You just get 100% no matter what.</font>
<font size=3 face="Times New Roman"> </font>
<font size=2 color=#000080 face="Arial">I called Vee support, and theysaid only one other person had called about the problem. I thinkthe problem needs to be escalated to make sure it gets fixed in the nextrelease because he said he did not know when it would be fixed.</font>
<font size=2 color=#000080 face="Arial">Any comments from the supportteam within Agilent on whether this is going to be fixed? </font>
<font size=2 color=#000080 face="Arial">I have a program that has beenrunning at least 5 years using the Print Screen function, and it’s onmany testers. I tried upgrading to Vee 7, but had to downgrade ithoping it will be fixed sometime soon. </font>
<font size=2 color=#000080 face="Arial">I might have to create somekind of a Word document as a report and print that if I have to.</font>
<font size=2 color=#000080 face="Arial">Kirk Reed</font>
<a href=mailto:Kirk_reed@agilent.com><font size=2 color=blue face="Arial"><u>Kirk_reed@agilent.com</u></font></a>
From:</b> Brian Pittman [mailto:bpittman@comtechefdata.com] <b>
Sent:</b> Friday, March 25, 2005 1:14 PM<b>
To:</b> VRF<b>
Subject:</b> [vrf] VEE 7 Print Screen Problem</font>
<font size=2 face="MS Sans Serif">Hello VRF,</font>
<font size=2 face="MS Sans Serif">The Print Screen object changed whenwe upgraded to VEE 7 from VEE 6. Now the Print Screen object sendsa screen capture to the printer; before it only sent the contents of theVEE window to the printer. Now every time another program createsa pop-up window on top of VEE's window the data is hidden behind the pop-upwhen the Print Screen object is executed.</font>
<font size=2 face="MS Sans Serif">We cannot eliminate all the pop-upsfrom the system (some are generated by IT Dept software, etc...), and Idon't want to downgrade our systems to VEE 6.</font>
<font size=2 face="MS Sans Serif">Using VEE 7, is there a way to senda copy of the VEE window to the printer without using the Print Screenobject?</font>
<font size=2 face="MS Sans Serif">Thanks,</font>
Brian Pittman
ATE Design Technician
Comtech EF Data Corp.</font>
<font size=2 face="MS Sans Serif">---
You are currently subscribed to vrf as: kirk_reed@agilent.com
If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</font><p><font size=3>---
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
<font size=3>---
You are currently subscribed to vrf as: paul.sylvester@philips.com
---You are currently subscribed to %%list.name%% as: %%emailaddr%%To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
> Screen object?
There is, but I'm afraid it's pretty obscure by VEE standards. The old
PrintScreen example accomplishes this by copying the VEE window as a bitmap
and blasting it off to the printer.
Detlef courteously collected up all the information that I spread over
several different messages in one single posting with the most recent
http://www.oswegosw.com/SearchVRF.php?mi=11099
This example could probably use some upgrading to VEE 7 - I'm pretty sure it
would be a lot simpler via .NET rather than the GDI api. It's still a
classic Windows programming example though
VEE4Windows.
Alternatively you could use a custom window printing control or library -
it's a very easy thing to do and I'm sure such things exist although I don't
personally know of any. Maybe search for capture or capture and print or
something.
And about the archive - I see the general notice hasn't shown up yet so just
so y'all know: when it does, forget about it. The power is now back on and
stable.
-SHAWN-
> Screen object?
VEE4Windows.
something.
stable.
-SHAWN-
> Screen object?
VEE4Windows.
something.
stable.
-SHAWN-
> VEE standards.
Holy cow I'm wrong again!
It seems that something else has changed. This works for VEE 5 with popups
over it but not VEE 7 (which I guess is the source of your problem). I can't
imagine what the difference is.
At any rate, forget about PrintScreen.vee. What you need to do is put VEE on
top of any active popups. You can do this by any of several methods.
Probably the easiest is: if you have a script control installed then you can
instance the script library and do AppActivate("Agilent VEE Pro -
<whatever>") where <whatever> is your program name.
If you don't want to create dependencies, then you can call hWnd =
user32.FindWindow("AgilentVEE", 0); user32.BringWindowToTop(hWnd);
Note that both of these methods will only work if the popups are *not* so
called "top-most" windows (those windows that always stay on top of all
other windows regardless of which one is activated). If that's the case,
then the easiest thing to do is to find the offending windows that are in
the way and move them out of the way before executing the PrintScreen
object.
-SHAWN-
> VEE standards.
object.
-SHAWN-
> VEE standards.
object.
-SHAWN-
> to find the offending windows that are in the way
> PrintScreen object.
Or how's this for a twist: move the VEE window off screen. I'm not
absolutely sure, but I think that won't affect it's redraw. Move it off,
execute a PrintScreen object, then move it back to where it was. In that
case you only have to find one window whose class you already know - not
several unspecified windows whose classes and titles may be variable.
-SHAWN-
> PrintScreen object.
-SHAWN-
> PrintScreen object.
-SHAWN-
It looks like Qi is right. I can't get the bloody thing to work now.
However, I promise I'll mess with it and see what I can come up with.
Specifically for version 7.
-SHAWN-
-SHAWN-
-SHAWN-
<b><span style='font-weight:bold'>From:</span></b> Brian Pittman[mailto:bpittman@comtechefdata.com]
<b><span style='font-weight:bold'>Sent:</span></b> </span></font><font size=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'>Friday, March 25, 2005</span></font><font size=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'> </span></font><font size=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'>1:14 PM</span></font><font size=2face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'>
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] VEE 7 Print ScreenProblem</span></font></p><p class=MsoNormal style='margin-left:.5in'><font size=3 face="Times New Roman"><spanstyle='font-size:12.0pt'> </span></font></p><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>Hello VRF,</span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'> </span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>The Print Screen objectchanged when we upgraded to VEE 7 from VEE 6. Now the Print Screen objectsends a screen capture to the printer; before it only sent the contents of theVEE window to the printer. Now every time another program creates apop-up window on top of VEE's window the data is hidden behind the pop-up whenthe Print Screen object is executed.</span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'> </span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>We cannot eliminate allthe pop-ups from the system (some are generated by IT Dept software, etc...),and I don't want to downgrade our systems to VEE 6.</span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'> </span></font></p></div><div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>Using VEE 7, is there away to send a copy of the VEE window to the printer without using the PrintScreen object?</span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'> </span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>Thanks,</span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'> </span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'> </span></font></p></div><div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>
Brian Pittman
Comtech EF Data Corp.</span></font></p></div></div><p class=MsoNormal style='margin-left:.5in'><font size=2 face="MS Sans Serif"><spanstyle='font-size:10.0pt;font-family:"MS Sans Serif"'>---
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com". </span></font></p></div>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></html>
Brian Pittman
Brian Pittman
generation or both? Would basic HTML functionality be good enough? Think
basic text generation & maybe some table stuff.
-SHAWN-
-SHAWN-
-SHAWN-
Ok it won't be able to drive a motorcycle through the desert...
> (Hah! Let's put everything in there - it slices, it dices...)
Well there's a couple different deals. Firstly, it won't be like Crystal
Reports or anything like that ('cuz there's already Crystal Reports
more of a simple report generator. Second it won't actually render rtf or
html because there're already controls to do that.
It's specification should be more or less simple. IOW it won't actually
interpret input text - if that's a requirement then one might as well use a
Rich Text control or an html control. It should be easy to use. No more
difficult than an Alphanumeric ideally, though it won't be a VEE object but
rather a COM object - probably an Automation library since there's no need
for a visible representation.
It could have two basic purposes: to snap and print or display (in a
browser) an image of the VEE execution window, allowing for scaling,
orientation and printer selection (naturally all programmatic so no user
interaction is necessary) and the generation & printing or display (in a
browser) of simple reports. Another output option would be to generate an
image or html file (for both functions).
I remember well my days as a typographer, and though I recognize the
superiority of inserting type commands in the text stream the simplicity of
pressing a button to change fonts or sizes is hard to ignore. I'm thinking
of simple calls like SetFont(name), SetSize(size), SetColor(color),
TableHead, TableRow, ListStart, ListEnd and so forth. Call a function, send
some text, call another function, send some more text... accumulate a report
and then print it or show it or write it to disk.
It doesn't do great things like Word or Excel but it gives you a little more
flexibility than simple objects alone (did anybody ever figure out how to
print a Rich Text or HTML control image? - that would make this unnecessary
more or less).
> Are ya gonna write it, Shawn?
I'll do whatever will pay the bills for a couple months! Still there's a lot
of stuff going on at the moment & I doubt I could give it a try any time in
the next week or two.
-SHAWN-
more or less).
-SHAWN-
more or less).
-SHAWN-
graphs generated in VEE. This could be used for on-screen reports too,
emailing, or a status web-page? (Hah! Let's put everything in there - it
I've always wanted to be able to change colours on the logging alphanumeric
on the fly, to flag certain lines as failures, for instance...I suppose this
could be done in html, right?
Are ya gonna write it, Shawn? I played with this very briefly a while ago,
but, never had time to go anywhere with it...
Reiner
Sent: Tuesday, March 29, 2005 1:57 PM
To: VRF
How should this work: Would it be strictly for report generation, VEE image
-SHAWN-
Reiner
To: VRF
-SHAWN-
Reiner
To: VRF
-SHAWN-
Jeff Davis
CDI Engineering Solutions Aerospace Technologies
Embedded Systems and Electronics
3137 E Elwood #160
Phoenix, Arizona 85034
Phone: (602)431-4497 (x226)
Cell: (480)330-1431
Fax: (602)431-4435
> From: Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
> Sent: Tuesday, March 29, 2005 12:59 PM
> To: VRF
> Well, we want everything, right? It would be nice if it could display
> reports too,
> in there - it
> Reiner
> To: VRF
> enough? Think
> -SHAWN-
> You are currently subscribed to vrf as: jeff.davis@cdi-es.com
> _____________________________________________________________________
> This e-mail message has been scanned for the presence of all
> known computer viruses by the MessageLabs Virus Control
> Center. However, it is still recommended that you use local
> virus scanning software to monitor for the presence of viruses.
This e-mail has been scanned for viruses by MCI's Internet Managed Scanning Services - powered by MessageLabs. For further information visit http://www.mci.com
Jeff Davis
3137 E Elwood #160
Cell: (480)330-1431
Fax: (602)431-4435
> To: VRF
> reports too,
> in there - it
> Reiner
> To: VRF
> enough? Think
> -SHAWN-
Jeff Davis
3137 E Elwood #160
Cell: (480)330-1431
Fax: (602)431-4435
> To: VRF
> reports too,
> in there - it
> Reiner
> To: VRF
> enough? Think
> -SHAWN-
> as a front end to VEE 5.
Beautiful! Well I guess in that case there's no need for this punky library
so I'll concentrate on getting rid of popup images that cover the VEE
window. Eventually
Incidentally we're supposed to be playing wild wind vortex roulette later
this afternoon so don't be surprised if the archive goes down for a while
during the storms.
-SHAWN-
window. Eventually
during the storms.
-SHAWN-
window. Eventually
during the storms.
-SHAWN-
> did anybody ever figure out how to print a Rich Text or HTML control
image? - that would make this unnecessary more or less.
I've been using the IE WebBrowser_V1 control (shdocvw.dll) as a front end
to VEE 5.
I size the control nice and big on its own panel, then I can show or hide
it at will while I change the content.
Cutting a long story short, I generate the HTML / Javascript on the fly
using formula boxes or 'to string' objects and write it out as a text array
to the control's associated Document object (Document.writeln)
For every page I generate, I have a standard header containing several
hidden form fields.
When a link or button is clicked on my page, I use some Javascript to
populate those fields with the name of the VEE function I wish to call, and
any parameters to pass to it.
I then use the Javascript 'raiseEvent' function to raise a particular
Document event - in most cases I use 'Stop'.
I have a VEE event handler function for the Stop event that reads the
contents of my hidden fields (Document.form.field.value) and builds and
executes the appropriate formula call.
I can reference the Document's display objects from within my Vee code, so
can easily change display attributes on the fly such as colour, text size,
show/hide/change images etc
This has all the other advantages that have already been mentioned, and
more - tables, images, image maps, animation, forms, mouse-overs,
hyperlinks, CSS, cool javascript tricks
Back to the point: Printing.
The IE contol provides a function 'showModalDialog' with which you can show
a browser window of any size with no toolbars etc, containing an HTML doc
that you specify.
The window has modal properties, so the user cannot continue without
closing it first.
Most shortcut keys are disabled, with the notable exception of <ctrl>+p
which shows the print dialog.
I use this functionality to generate test reports, using CSS to size them
nicely for printing and insert page breaks (this is the tricky bit !).
My users can display the report and then hit <ctrl>+p to print it to their
favourite printer
Anything can be included in the report that can be included in an HTML
page: coloured text, different fonts, images etc.
Tables can be used to lay it all out nicely.
This may not be everyones cup of tea, and can get complicated quite
quickly, but I've had some really nice results with it.
Paul F.
| "Shawn | Document Marked as Unclassified | |
|Fessenden| | |
|<shawn@te| | |
|stech-ltd| | |
| .com> | | |
"Shawn Fessenden" To: VRF <vrf@agilent.com>
<shawn@testech-ltd.co cc:
m> Subject: RE: [vrf] VEE 7 Print Screen Problem
29/03/05
21:35
Please respond to "Shawn
Fessenden"
Stationery name:-Untitled-
report
more
more or less).
lot
-SHAWN-
You are currently subscribed to vrf as: Paul.Fowler@raytheon.co.uk
to VEE 5.
hidden form fields.
that you specify.
closing it first.
favourite printer
Paul F.
|Fessenden| | |
|<shawn@te| | |
|stech-ltd| | |
| .com> | | |
29/03/05
21:35
Fessenden"
report
more
more or less).
lot
-SHAWN-
to VEE 5.
hidden form fields.
that you specify.
closing it first.
favourite printer
Paul F.
|Fessenden| | |
|<shawn@te| | |
|stech-ltd| | |
| .com> | | |
29/03/05
21:35
Fessenden"
report
more
more or less).
lot
-SHAWN-
Paul Sylvester
3000 Minuteman Road
Andover, MA 01810
978-659-4836
</table>
To:</b> VRF<b>
</font>
To:</b> VRF<b>
Brian Pittman
<font size=3>---
Paul Sylvester
3000 Minuteman Road
Andover, MA 01810
978-659-4836
</table>
To:</b> VRF<b>
</font>
To:</b> VRF<b>
Brian Pittman
<font size=3>---
