Make sure you don't start your subject with "Delete"
From: Lyris ListManager [mailto:lyris-noreply@it.lists.it.agilent.com]
Sent: 20 June 2005 10:16
To: SPANGENBERG,SASCHA (A-Scotland,ex1)
Subject: Re: Delete Variables at Prerun Option Clears Itself
Sorry, your message was not sent out to 'vrf'
because the first word of your subject looks very similar to a system
command.
If it is a command, you should email it to:
lyris@it.lists.it.agilent.com
Or, if you want to unsubscribe, send email to:
leave-vrf-432829U@it.lists.it.agilent.com
If your message is definitely not a command, and is instead an email
message that
everyone on vrf should receive, then you should re-send your message,
changing the first word so that it does not cause this warning.
The rejected text was:
