Michael Watts <Mike@PreciselySo.Co.UK> wrote:
> Just wanted to say thanks for all the contributions on setting panel
> size - seems that I'm not the first one to want to do this!
> In Stan's [Bishof's] simple example it is easy to find the panel setting
> for "UserFunction1" but in a real application it's not so
> straightforward. If I find a 'search algorithm' I'll let you know. I
> have enough to be going on with for now
Odds are you will find this is pretty straightforward. The VEE
file syntax is quite regular and is pretty easy to parse. If you know
the name of the function you could write a routine to find that
function, then find the panel size setting and modify it. When you modify
source like this though be quite careful as the syntax is unforgiving.
Stan
Stan
