when I do it with a error output, than I don't get a error.
The reason for the former error seams to be in the back-reading from the "direct I/O", but he didn't send something to the interface.
I can control it on the bus activity.
What can be responsible for the different beetween runtime an development in writing to direct I/O ?
Thomas
-------- Original Message --------
Subject: RE: [vrf] [VRF] error in runtime but not in development surrounding (12-Aug-2005 13:37)
To: tw@huber-online.com
> > Is that a problem with a error output?
> Probably not. Defaults such as current directory can be different.
> Suggestion: send your string to a message box before it gets to the From
> String in question. This will help you figure out what's going on.
> -SHAWN-
> vrf@agilent.com
To: shawn@testech-ltd.com
Cc: vrf@agilent.com
Thomas
> -SHAWN-
> vrf@agilent.com
Cc: vrf@agilent.com
Well, if the error output is wired to a Message Box what happens? Catching
an error is not the same as catching an error and doing something about it.
Then again, I'm pretty sure you know the difference so...
> I/O ?
The file vee.io for one thing (maybe). It depends on how things are set up,
whether or not your IO Config is embedded, how you start the runtime...
-SHAWN-
