<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><TITLE>Message</TITLE><META http-equiv=Content-Type content="text/html; charset=us-ascii"><META content="MSHTML 6.00.2800.1505" name=GENERATOR></HEAD><BODY><DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2></FONT> </DIV><SPAN class=168114022-13092005></SPAN><FONT face=Arial><FONT color=#0000ff><FONT size=2>Appologies if you get this twice. I never saw it come across. Dave<SPAN class=168114022-13092005></SPAN></FONT></FONT></FONT><BR><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><HR tabIndex=-1><FONT face=Tahoma size=2><B>From:</B> Andersen, Dave-P26278 <BR><B>Sent:</B> Tuesday, September 13, 2005 2:40 PM<BR><B>To:</B> 'Findley, Robin'; VRF<BR><B>Subject:</B> RE: [vrf] Serial problem<BR></FONT><BR></DIV><DIV></DIV><DIV dir=ltr align=left><SPAN class=202302921-13092005><FONT face=Arial color=#0000ff size=2>Well, unless the device was sending garbage or I have a very noisy line, one app I was using was a transmit only one-way communication setup. This was a homemade device using a PIC controller. A bus monitor never showed anything returning.</FONT></SPAN></DIV><DIV dir=ltr align=left><SPAN class=202302921-13092005><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV dir=ltr align=left><SPAN class=202302921-13092005><FONT face=Arial color=#0000ff size=2>Dave</FONT></SPAN></DIV><BR><DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><HR tabIndex=-1><FONT face=Tahoma size=2><B>From:</B> Findley, Robin [mailto:rfindley@harris.com] <BR><B>Sent:</B> Tuesday, September 13, 2005 2:04 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> RE: [vrf] Serial problem<BR></FONT><BR></DIV><DIV></DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2>Dan,</FONT></SPAN></DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2>Maybe you are onto something... I never had problems with VEE's serial interface until I started communicating with a device that continually dumps data. My most recent project involves one such piece of equipment, and VEE has been giving me the same SICL timeout error. Since I was unable to solve the problem, I started using MsComm instead, and haven't had any problems since.</FONT></SPAN></DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2>Has anyone had this error while using equipment that _doesn't_ fill the receive buffer?</FONT></SPAN></DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV><DIV><SPAN class=743485120-13092005><FONT face=Arial color=#0000ff size=2>-Robin</FONT></SPAN></DIV><BLOCKQUOTE style="MARGIN-RIGHT: 0px"> <DIV></DIV> <DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Williams, Dan [mailto:Dan.Williams@analog.com] <BR><B>Sent:</B> Tuesday, September 13, 2005 12:25 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> RE: [vrf] Serial problem<BR><BR></FONT></DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2>I don't know if it's of any use but in programming an RS232 to I2c interface I had a year of intermittent problems. What I eventually discovered was the VEE routines written for the interface by a co-op were allowing garbage data to build up in the buffer of the interface so most of the time it would work well and once in a while the timing of input/output would be off and the buffer would send out data generated by a previous error condition. I fixed it by writing a routine that at the beginning of an operation continuously reads from the buffer and releases when the end of buffer error is generated ensuring no left over data to bung up the works. Since I do characterization the time penalty for doing this is minimal. You production guys will feel otherwise I'm sure.</FONT></SPAN></DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2>This should have been easy to figure out but it's intermittent nature made it a bear to find.</FONT></SPAN></DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2></FONT></SPAN> </DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2>Dan Williams</FONT></SPAN></DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2>Analog Devices </FONT></SPAN></DIV> <DIV><SPAN class=292401017-13092005><FONT face=Arial color=#0000ff size=2>High Speed Networking</FONT></SPAN></DIV> <BLOCKQUOTE style="MARGIN-RIGHT: 0px"> <DIV></DIV> <DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> George Tyrrell [mailto:tdllc01@earthlink.net] <BR><B>Sent:</B> Tuesday, September 13, 2005 12:52 PM<BR><B>To:</B> VRF<BR><B>Subject:</B> RE: [vrf] Serial problem<BR><BR></FONT></DIV> <DIV>I have 4 WinNT 4.0 workstations with all the latest updates running VEE 5.01. All of the workstations are networked to common shared resources. I send data out of the serial port to a B&B RS-232 to CAN converter for DeviceNet support.</DIV> <DIV> </DIV> <DIV>Only one of these workstations displays this problem. Restarting VEE does not help. Rebooting does not help. Disconnecting the network does not help. Changing to another CAN converter does not help. Upgrading the IO libraries version does not help. Changing to the other internal COM port works briefly.</DIV> <DIV> </DIV> <DIV>What DOES work is to disconnect the RS-232 port from the B&B converter, then send out serial data and attempt to receive serial data from that open port. This deliberately generates another error. </DIV> <DIV> </DIV> <DIV>Following the deliberate error, communication through the serial port is restored until the same error occurs again, usually a week later. My technicians have instructions on how to reset using this technique.</DIV> <DIV> </DIV> <DIV>I don't understand why only one of my computers has this problem. They are all of the same manufacturer (HP), configured the same way. Apparently this problem is still lurking in the background, and is OS independent. But is it still in the later VEE revisions? I'm suspecting that it may be hardware timing dependent.</DIV> <DIV> </DIV> <DIV>George Tyrrell</DIV> <DIV>TestDynamics LLC</DIV> <DIV>Thornton, Colorado<BR><BR><BR>-----Original Message----- <BR>From: "Andersen, Dave-P26278" <DAVE.ANDERSEN@GDC4S.COM><BR>Sent: Sep 13, 2005 10:17 AM <BR>To: VRF <VRF@AGILENT.COM><BR>Subject: RE: [vrf] Serial problem <BR><BR></DIV><ZZZHTML><ZZZHEAD><ZZZMETA content="text/html; charset=us-ascii" http-equiv="Content-Type"><ZZZMETA content="MSHTML 6.00.2800.1505" name="GENERATOR"></ZZZHEAD><ZZZBODY> <DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=604280616-13092005>I have run into this problem also and I do not have any other program running and am using a real com port. In fact, I can run the program, stop it (with an execute close), and when I restart I get the message. Could this be an XP issue? I don't recall this problem before running XP.</SPAN></FONT></DIV> <DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=604280616-13092005></SPAN></FONT> </DIV> <DIV dir=ltr align=left><FONT face=Arial color=#0000ff size=2><SPAN class=604280616-13092005>Dave</SPAN></FONT></DIV> <DIV><BR></DIV> <DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left> <HR tabIndex=-1> <FONT face=Tahoma size=2><B>From:</B> g.nied@gn-software.de [mailto:g.nied@gn-software.de] <BR><B>Sent:</B> Monday, September 12, 2005 2:53 AM<BR><B>To:</B> VRF<BR><B>Subject:</B> Re: [vrf] Serial problem<BR></FONT><BR></DIV> <DIV></DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">Tim,</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">the error message is leading you to the wrong direction. It only means that VEE cannot communicate with the port through the SICL library.</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">So the problem might be:</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">- another program took control over that specific serial port and did not close it</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">- if the serial port is only a virtual one (USB) and the USB connection was disturbed</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">In those cases a restart of VEE might be the solution, because SICl checks for the ports only once at VEE start.</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000">I hope that helps a bit,</DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000"> <DIV> <DIV> </DIV> <DIV>best regards,</DIV> <DIV> </DIV> <DIV>Georg</DIV> <DIV> </DIV> <DIV> </DIV> <DIV><IMG src="cid:604280616@13092005-03BF"></DIV> <DIV><FONT face="Century Gothic">Georg Nied · Software-Development · Hansestr. 7 · 51149 Cologne · Germany</FONT></DIV> <DIV><FONT face="Century Gothic">Tel: +49 (2203) 9770915 · Fax: +49 (2203) 9770924 · E-Mail: </FONT><A href="mailto:info@gn-software.de"><FONT face="Century Gothic">info@gn-software.de</FONT></A></DIV></DIV></DIV> <DIV style="FONT: 10pt Courier New; COLOR: #000000"> </DIV> <BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"> <TABLE id=tobit_repfor style="BORDER-RIGHT: #e0e0e0 1px solid; BORDER-TOP: #e0e0e0 1px solid; FONT: 10pt Arial; BORDER-LEFT: #e0e0e0 1px solid; COLOR: black; BORDER-BOTTOM: 0px" cellSpacing=0 cols=3 cellPadding=0 width="99%" border=0> <TBODY> <TR borderColor=#dfdfdf borderColorLight=#dfdfdf bgColor=#dfdfdf> <TD style="PADDING-LEFT: 4px; PADDING-BOTTOM: 1px; PADDING-TOP: 1px; BORDER-BOTTOM: #ffffff 1px solid" width=140 colSpan=2 height=22> <DIV style="FONT: bold 9pt Arial">Original Message </DIV></TD> <TD style="BORDER-BOTTOM: #ffffff 1px solid" align=right> <DIV style="FONT: 8pt Arial"> <DIV style="FONT: 8pt Arial"><STRONG><FONT color=#808080> processed by David InfoCenter</FONT></STRONG> </DIV></DIV></TD></TR></TBODY></TABLE> <TABLE id=tobit_repfor2 style="BORDER-RIGHT: #e0e0e0 1px solid; BORDER-TOP: 0px; FONT: 8pt Tahoma; BORDER-LEFT: #e0e0e0 1px solid; COLOR: black; BORDER-BOTTOM: #e0e0e0 1px solid" cellSpacing=0 cols=2 cellPadding=0 width="99%" border=0> <TBODY> <TR style="PADDING-BOTTOM: 2px"> <TD style="PADDING-LEFT: 6px; BORDER-BOTTOM: #ffffff 1px solid" width=68 bgColor=#efefef height=18> <DIV style="FONT: 8pt Tahoma">Subject: </DIV></TD> <TD style="PADDING-LEFT: 4px; BORDER-BOTTOM: #efefef 1px solid" bgColor=#ffffff> <DIV style="FONT: 8pt Tahoma">[vrf] Serial problem (09-Sep-2005 16:08)</DIV></TD></TR> <TR style="PADDING-BOTTOM: 2px"> <TD style="PADDING-LEFT: 6px; BORDER-BOTTOM: #ffffff 1px solid" width=68 bgColor=#efefef height=18> <DIV style="FONT: 8pt Tahoma">From: </DIV></TD> <TD style="PADDING-LEFT: 4px; BORDER-BOTTOM: #efefef 1px solid" bgColor=#ffffff> <DIV style="FONT: 8pt Tahoma"><A href="mailto:Tim.Fisher@gdc4s.com">Tim.Fisher@gdc4s.com</A></DIV></TD></TR> <TR style="PADDING-BOTTOM: 0px"> <TD style="PADDING-LEFT: 6px" width=68 bgColor=#efefef height=17> <DIV style="FONT: 8pt Tahoma">To: </DIV></TD> <TD style="PADDING-LEFT: 4px" bgColor=#ffffff> <DIV style="FONT: 8pt Tahoma"><A href="mailto:vrf@agilent.com">vrf@agilent.com</A></DIV></TD></TR></TBODY></TABLE> <DIV> </DIV><ZZZ!-- -- format rtf text from Converted> <P><FONT face=Arial size=2>Hello all,</FONT> </P> <P><FONT face=Arial size=2>I am receiving a serial error which I'm sure has come up before for others, so maybe I can get some advice. I am receiving a VEE Run Time Error</FONT></P> <P><FONT face=Arial color=#ff0000 size=2>I/O error or timeout occurred SICL call made with bad parameter</FONT> </P> <P><FONT face=Arial color=#ff0000 size=2>Unable to set receive buffer size of X bytes</FONT> <BR><FONT face=Arial color=#ff0000 size=2>In transaction number 1</FONT> </P> <P><FONT face=Arial size=2>I have tried a wide range of values for the receive buffer (X = 32 to 8192)</FONT> <BR><FONT face=Arial size=2>But none of the values have worked. Also the problem only seems to occur when the remote host is connected to a shared network.</FONT></P> <P><FONT face=Arial size=2>Any help would be appreciated.</FONT> </P> <P><FONT face=Arial size=2>Thanks,</FONT> <BR><FONT face=Arial size=2>Tim Fisher</FONT> </P></BLOCKQUOTE></ZZZBODY></ZZZHTML>--- You are currently subscribed to vrf as: Dan.Williams@analog.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". </BLOCKQUOTE><BR>--- <BR>You are currently subscribed to vrf as: rfindley@harris.com <BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". <BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". <BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". <BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". </BLOCKQUOTE><BR>--- <BR>You are currently subscribed to vrf as: Dave.Andersen@gdc4s.com <BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". <BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". <BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". <BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". <BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></HTML>
