Sorry for late - this is more of a test than anything. Please excuse my prattling - I know it's unnecessary
> Instead of sending to printer, we want to send it to word, acrobat
> reader or another tool like them. Is it possible?
Yes! Code Cow (huh? is right, along with everybody else. If you buy Acrobat you get a creator which installs a printer driver that makes pdf files. Ghostscript is another great choice. What I've done in the past is add an Apple LaserWriter printer & connect it to a File: port. The result is an .eps file that's viewable with Ghostscript or any post script viewer, as well as a file that you can send to a LaserWriter with a Copy /b command. Very handy.
Using a print object or to printer always uses the default printer, which is sometimes not what you want. There was a whole series of discussions on this. You can invoke the Print dialog, or you can programmatically set the printer with DefaultPrinter.vee if you want. You can find all this stuff in the archive. Search at http://www.oswegosw.com/vrf_archive/SearchVRF.htm
-SHAWN-
-SHAWN-
command line prompt to open the txt file that you just created.
Regards, Gary
Sent: Sunday, January 02, 2005 10:35 PM
To: VRF
Subject: [vrf] Documentation of VEE program
Hi VRF,
We want to use print program property of VEE Pro for a different purpose.
Instead of sending to printer, we want to send it to word, acrobat reader or
another tool like them. Is it possible? If yes, could you please advice me.
I will use this property for documentation purposes.
Best regards
Murat COSKUN
Dikkat:
Bu elektronik posta mesaji kisisel ve ozeldir. Eger size
gonderilmediyse lutfen gondericiyi bilgilendirip mesaji siliniz.
Firmamiza gelen ve giden mesajlar virus taramasindan gecirilmekte,
guvenlik nedeni ile kontrol edilerek saklanmaktadir. Mesajdaki
gorusler ve bakis acisi gondericiye ait olup Aselsan A.S. resmi
gorusu olmak zorunda degildir.
Attention:
This e-mail message is privileged and confidential. If you are
not the intended recipient please delete the message and notify
the sender. E-mails to and from the company are monitored for
operational reasons and in accordance with lawful business practices.
Any views or opinions presented are solely those of the author and
do not necessarily represent the views of the company.
bç®·&vÚvHNnljzwnV[Xj z{d{nljzwnV[zÙ²ÛµrvgÚ†+j) j)W!wv Ø™xzwj z~+´֊W
