In short, I need to know if VEE Pro 7.5 is capable of communicating and aquiring data from the MODBUS (RS485?? im not sure) protocol.
I have searched google to look for drivers for a MODBUS protocol that is specifically written for easy communication in VEE (as my programming abilities are weak) but have not found anything (that I recognise).
What I am proposing to eventually do is setup a power meter to measure power consumption and then have these results read remotely over a network into a basic VEE program I have made. The company I work for has yet to purchase the aforementioned power meter as we are worried about compatibility into VEE with the MODBUS protocol.
Thank you for trying to help, I will be happy to explain anything again if something is unclear.
From Niraj Patel
To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".
From Niraj Patel
SaveAs xlHtml = 44. See attached (for IIS). If you need to authenticate to a
web site (like, it's not on the same computer) then that's a different
story. It depends on how the web site is setup.
-SHAWN-
