Perhaps, but you can download it as part of the SDK: http://msdn.microsoft.com/library/defau ... nlevel.htm
This is a freely accessable download.
Â
Bear in mind that winsock is pretty antiquated at this point; and as you already have .NET in hand, you may be better served to do some investigation into .NET sockets instead.
Here is the MSDN reference to the Sockets implementation:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/frlrfsystemnetsockets.asp
Â
 _____ Â
Sent: 03 March 2006 09:26
To: VRF
Subject: Re: [vrf] winsock issue
Hi Yoon,
MS Winsock ActiveX library is not freely distributable. you can not just copy the ocx file from another PC an register again to develop your programs. However if you write your programs on a platform where MS Winsock ActiveX is installed, you can distribute the vee file to another PC where Activex was not registered.
So you have to install Visual C++ to have the ActiveX.
Â
I recommend you to use winsock 2 API (ws2_32.dll). I remember that shawn has posted a sample VEE code to VRF. Also you can developed a VEE compatible bridge dll too.
Â
Good Luck
zafer
----- Original Message -----
From: HYPERLINK "mailto:yyp_0105@yahoo.com"yoon park
To: HYPERLINK "mailto:vrf@agilent.com"VRF
Sent: Wednesday, March 01, 2006 12:07 AM
Subject: [vrf] winsock issue
hi all,
i am trying to generate a UDP packet with winsock as shown on the below website.
http://www.evaluationengineering.com/archive/articles/0400soft.htm
one problem that i am faced with is that i cannot locate Winsock ActiveX control library. i have downloaded Visual C++ Express Edition and purchased both Visual Studio .NET and Visual Studio 2005. is that library supposed to be included in any of the above applications and i just can't locate them? or was i searching at wrong places?Â
please help.. i am having so much problem over this. also, is there any downloadable application out there for free which supplies Winsock ActiveX control?
Â
thank you!
 _____ Â
Yahoo! Mail
Bring photos to life! HYPERLINK "http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=39174/*http://photomail.mail.yahoo.com"New PhotoMail makes sharing a breeze. --- You are currently subscribed to vrf as: zsavas@aselsan.com.tr To subscribe send a blank email request to "join-vrf@lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
 _____ Â
Dikkat:
Bu elektronik posta mesaji kisisel ve ozeldir. Eger size gonderilmediyse lutfen gondericiyi bilgilendirip mesaji siliniz. Firmamiza gelen ve giden mesajlar virus taramasindan gecirilmekte, guvenlik nedeni ile kontrol edilerek saklanmaktadir. Mesajdaki gorusler ve bakis acisi gondericiye ait olup Aselsan A.S. resmi gorusu olmak zorunda degildir.
 _____ Â
Attention:
This e-mail message is privileged and confidential. If you are not the intended recipient please delete the message and notify the sender. E-mails to and from the company are monitored for operational reasons and in accordance with lawful business practices. Any views or opinions presented are solely those of the author and do not necessarily represent the views of the company.
 _____ Â
Â
You are currently subscribed to vrf as: Esbachb@tycoelectronics.com
To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
leave the subject blank and in the message body put only the word "subscribe"
Â
Â
 _____ Â
To: VRF
Hi Yoon,
Â
Â
Good Luck
zafer
hi all,
Â
thank you!
 _____ Â
Yahoo! Mail
 _____ Â
Dikkat:
 _____ Â
Attention:
 _____ Â
Â
> website.
Looks ok, but I have one problem with this: the port is way, way too low.
I'm astounded that an IEEE member would teach bad manners. Port 4444 (both
TCP and UDP) is reserved for krb524, aka Kerberos, an authentication
protocol. You'll get yourself into all kinds of trouble with IT on networks
that use Kerberos if you use 4444.
The IANA port range for temporary or unregistered ports is 49152-65535.
Visual C++ 5 or 6 contains it for sure, but it is not installed by default.
You have to either select a full install or select custom and check ActiveX
Controls.
-SHAWN-
