> The HpVEE version I'm using is 4.0
Bummer - IIRC 4 doesn't support ActiveX. Is it Kathy that uses this technique?
http://www.oswegosw.com/SearchVRF.php?an=dde
No I guess it's Ashley. Hm, latest to earliest would probably be better huh?
Guess I wasn't thinking. Ok, gimme a minute...
-SHAWN-
To subscribe send a blank email request to "join-vrf@lists.it.agilent.com".
-SHAWN-
OK
> and GPIB National Instruments card board
(OK, but not relevant)
> to mesure electrochemical signs. The comunications between
> hardware and software are ok. Set-up straight!
> I have some doubts about how to get the data from the panel driver
Right click on the right side of the panel. It brings up a menu
which includes "Add Terminal -> Data Output." Click that, then select
the component you want (if you know the name.) If you don't know the
name, use "Select Terminal by Component", then click on the widget
you want to output. Wire either of these to the Excel file.
> and save it as a file (EXEL e.g.).
~Les Hammer
VP of Engineering
Smart Sensor Systems
720 14th Street SW
Loveland, CO. 80537-6349
Les.Hammer@SmartSensorSystems.com
Les.Hammer@CompleteTest.com
