Hi Les,
This should be possible. I have written stuff for some of the older HP/Agilent products that could dump their screen via HPGL. If I recall, the trick is to basically issue the 'dump screen' command and then read the string that is output from the instrument. Read the string back and save it to a file. To import the picture into an MS-Office package you will need the MS HPGL graphics filter - download from the MS site (Search on HPGL filter should do it).
Let me know if you want an example for a HP instrument (sorry no R&S!)
Andy
From: lesord@ntlworld.com [mailto:lesord@ntlworld.com]
Sent: 29 July 2005 21:22
To: VRF
Subject: [vrf] simulate a HP plotter
Hi everyone,
has anyone used VEE (I'm using VEELab 5.02 but have limited access to 7.0) to read the output from an instrument when it is made to plot? I particularly want to be able to get the HPGL plot string from a Rohde & Schwarz FSA spectrum analyser but it doesn't have an output plot command (unlike some other instruments). It does have a command to make it plot to a plotter, "PLOT:SCREEN" and does allow Pass Control. So does anyone know how to get VEE to act as the plotter and therefore be able to capture the HPGL data?
Any code samples would be greatly appreciated.
Les
Email sent from http://www.ntlworld.com/
Virus-checked using McAfee(R) Software
Visit www.ntlworld.com/security for more information
You are currently subscribed to vrf as: andy_street@agilent.com
Andy
To: VRF
Hi everyone,
Les
Wow!
tokenized vector speak on a serial interface... so yeah, I don't see why you
couldn't do it. You could capture the serial bytes at any rate. Just toss
the bytes in a file and presto - you should have a ready made hpgl file.
>From there you should be able to read it into almost any graphic object. Er,
come to think of it, you may have to do a bit of searching to find an object
that will read hpgl (don't know, haven't worked with it for some time).
At any rate, this stuff may prove invaluable:
http://www.wotsit.org/search.asp?s=hpgl
(Shameless plug) WOTSIT'S FORMAT RULES!
-SHAWN-
