I have multiple threads running inside a program. I want to run process two
ONLY after process one has finished. I may, in fact, want to run process two
multiple times but I eventually want to run process one again. And, I don't
want to be able to run process two while one is running. I cant figure out how
to do this. If I tie a thread from process one to the until break of process
two I can never get back to process one. Any help is appreciated
So you really don't want independent threads at all- you just want
two routines controlled within one program.
I'd suggest writing the two routines as functions then add
a little controlling logic to decide which to run and when.
Or- if you really want physically disconnected threads
to be logically connected then use flags. At the start of each routine
set a global variable that says that routine is running. And of
course at the front of each check to see if the other is running
by looking at the appropriate variable.
regards
Stan
regards
Stan
Has anyone had to emulate a VT100 through the RS232, using direct I/O's?
Just no reponse from the piece of kit I'm trying to contact, but works fine
in Hyperterminal.
All the stop bits, parity baud rate etc etc are correct - just appears to
be this lack of VT-100 emulation causing the trouble.
If anyone has ever had to do this slightly strange requirement, it would be
great to hear from you...
Many thanks,
Al.
(VEE 7, I/O libraries M, Win2000)
