Shawn, Thanks for the input, I will have to figure out how to tell the non programmer engineers in China what to do to strip the config (after I do it mayself)
One point I forgot to mention, the computer is not connected to a network and there are no other programs running.
Ron P
-----Original Message----- From: Shawn Fessenden [mailto:shawn@testech-ltd.com] Sent: Thursday, April 14, 2005 11:37 AM To: Ron Pratt; 'VRF' Subject: RE: [vrf] Unexpected pause in Program
> Can anyone shed light on any other reason that would > cause that dialog box to appear?
Automatic update?
If automatic update is on and set to install updates automatically then the system will attempt to shut down and reboot.
However, I don't think that's the problem. It's more likely that a "not responding" dialog was tossed, and the command to end a task was given. In that case, the system will send a WM_CLOSE to the main window (which is exactly what happens when you click the close box).
As far as pausing goes, I can't offer the slightest clue. Well, maybe. Is the computer going into some kind of power saving mode where processes are paused? Or is a higher priority process hogging the CPU? I can't think of any possible explanation for a thread stopping for any length of time, short of waiting on hardware.
I'd recommend stripping the XP configuration down to minimum and observing. -SHAWN-
--- You are currently subscribed to vrf as: rsb@soco.agilent.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
Ron P
Automatic update?
Ron P
Automatic update?
-SHAWN-
