Hi All
I 'am using a USB Power Probe but the Agilent IO Library v14. can't detect It, therefore I can't use it in VEE 7
The Probe is a Rhode Schwartz NRP-Z11 connected by a NRP-Z4 cable to the USB port, the RS software works perfect. (Virtuel instrument)
I tried to connect a Agilent 34980A instrument by usb, this is auto detected in the IO suite and works fine.
The Problem is that you can't manual specify a USB instrument in the IO suite.
I tried to do this in Vee (Version 7 & 7.5) newInstrument3 ( @USB0::0x0aad::0x000c::100034::INSTR)
"USB::<vendor Id>::<product Id>::<serial number>"
But this just gives me a error 801.
So who don't fulfill the standard Agilent or Rhode Schwartz ..... Let the Battle begin
Kind Regards
Henrik Hald
Kind Regards
Henrik Hald
