vrf Callable VEE and VB net
Question asked by m.joseph on Oct 11, 2005
I'm sure that the variable is of the right type. I've done the same
program with VB .NET and it works perfectly.
The variable is a WinEASY_RemoteCtrl.Application object and OpenWsp is
a member of this class.
When I create the application object with VB .NET I've to write this code
on error resume next
set WEapp = CreatoObject("WinEASY_RemoteCtrl.Application")
on error goto 0
Do you think that I've to change the error processing in VEE as well
(if there is a way)?
Thanks.
Michele.
