vrf Debugging .NET (Collections)
Question asked by VRFuser on Jun 15, 2005
Yes thought of something like that but it's a bit too late when an error
occurred
since the program halts..
Of course I can add the foreach somewhere prior to the code that causes
the error
but I was hoping for a "realtime" **** probe..
Talking of hashes I also noticed I cannot dump a **** as a container to
a file.
(or any collection for that matter) by simply using a ToFile box and the
"container"
type.. I guess that can only be done via a foreach loop as well..
Sascha.
> -----Original Message-----
> From: GAO,QI (A-Sonoma,ex1) [mailto:qi_gao@agilent.com]
> Sent: 15 June 2005 19:33
> To: PDL-LISTS,VRF (A-Lists,unix1)
> Subject: RE: [vrf] Debugging .NET (Collections)
> You won't be able to "Step into" the Hashtable, but this
> should help you
> debug just the same.  Do you know the new ForEach object in
> VEE 7.5 can
> iterate .NET collections as well?
> Route the Hashtable to the input of ForEach, route the output
> of it to a
> formula box with one input like "entry", and write this:
> "Key " + entry.Key + "Value " + entry.Value
> Route the output from the formula box to a logging alphanumeric.
> Qi
> From: SPANGENBERG,SASCHA (A-Scotland,ex1)
> [mailto:sspangenberg@agilent.com]
> Sent: Wednesday, June 15, 2005 7:47 AM
> Subject: [vrf] Debugging .NET (Collections)
> Hi
> Is it possible to debug Collections at all?
> e.g. browse the content of a **** when an error occurred (just as
> I look at a record)
> The debug - Object Probe does not do the trick.
> Sascha.
> You are currently subscribed to vrf as: qi_gao@agilent.com
> To send messages to this mailing list,  email "vrf@agilent.com".
> You are currently subscribed to vrf as: sspangenberg@agilent.com
Subject: RE: [vrf] Data Shape Conversion
Date: Thu, 16 Jun 2005 08:07:14 +0100
From: "SPANGENBERG,SASCHA (A-Scotland,ex1)" <sspangenberg@agilent.com>
To: "BISCHOF,STAN (a-sonoma,unix1)" <stan_bischof@agilent.com>,
        "PDL-LISTS,VRF (A-Lists,unix1)" <vrf@agilent.com>
> or even easier-- use a "concatenator" with a single input.
Stan - what can I say... I'm moved!
What a beautiful solution
Love it - Thanks.
Sascha.
> Stan
> Stan Bischof  Agilent Technologies  707-577-3994
