> Is there any easy way to convert
> Decimal to Hex, not just for display,
> but where I can use in computations
> and in For Range loops??
If you mean as input, a formula will convert the major bases given the proper base. Even '0x' works (instead of #H). For other uses ToString HEX format works.
-SHAWN-
-SHAWN-
Â
Thanks
Shawn
Â
Shawn Bawell
Peregrine Semiconductor
11 Trafalgar Square
Nashua, NHÂ 03063
(W) 603-324-0090
sbawell@psemi.com
Â
Â
Reiner
 _____ Â
From: Shawn Bawell [mailto:sbawell@peregrine-semi.com]
Sent: Monday, July 10, 2006 9:23 AM
To: VRF
Subject: [vrf] Decimal to Hex
Is there any easy way to convert Decimal to Hex, not just for display, but where I can use in computations and in For Range loops??
Â
Thanks
Shawn
Â
Shawn Bawell
11 Trafalgar Square
Nashua, NHÂ 03063
(W) 603-324-0090
sbawell@psemi.com
Â
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
