Hi Rakesh,
If you have VEE Pro 7.5, the easiest way to do this is through the built-in VEE/Excel integration. If you have an earlier version of VEE, then there are some examples at the link below or just go to your examplesActiveXAutomation directory.
Qi
From: rakesh reddy vadyala [mailto:rakeshreddy.vadyala@gmail.com]
Sent: Friday, July 07, 2006 3:08 AM
To: VRF
Cc: VRF
Subject: [vrf] Generation of Excel sheets using VEE
Hi All:
Can anyone help me on the following process.
I am trying to automate the process of generating the excel sheets which takes data from couple of files (data like current readings from the power supply) and sends it to excel sheets where i can plot the results. All this procedue is needed to be implemented in VEE.
Can any one has any idea on how to go about this procedure.
Waiting for your reply,
Rakesh
> On 6/28/06, CHNG,KEONG-LEH (A-Malaysia,ex1) <keong-leh_chng@agilent.com> wrote:
> > Hi Scott,
> > There are some examples of VEE and Excel in the following link.
> > http://adn.tm.agilent.com/index.cgi?CONTENT_ID=2970
> > Regards...
You are currently subscribed to vrf as: qi_gao@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
Qi
To: VRF
Cc: VRF
Hi All:
Rakesh
> > Hi Scott,
> > Regards...
Rakesh
> > Hi Scott,
> > Regards...
