> All of this is a bit messy and user
> unfriendly particularly as the coms
> ports sometimes report 'unable to
> access port' and the only way out
> seems to be a reboot and start
> again approach.
You can use devcon to handle the USB side of things, but port assignment is handled elsewhere. I believe the stock handler just grabs the lowest available com port. With a little more work you could stop and restart the hub device which would probably be sufficient.
Try this first:
ftp://ftp.oswegosw.com/pub/devcon.exe
This is the 32-bit version. Type devcon /? for help.
-SHAWN-
> again approach.
Try this first:
-SHAWN-
> the attached code to create a new database?
There's no ISAM installed for Jet that's compatible with DAO.
> How do i solve this?
DAO is pretty dead. Use ADO instead. You'll still need an ISAM for Jet
though. The easiest way to get it is to install Access, but I believe you
can download these separately from Microsoft.
-SHAWN-
