vrf Defining Global Variable consisting of a record of records
Question asked by VRFuser on Aug 1, 2006
"HOUSTON,TOM" <tom.houston@avagotech.com> wrote:
> I routinely use a record that contains other records when reading in a
> configuration data file.  I would like to declare a Global and assign
> this data structure.
> I have a record of 8 text fields that contain individual switch
> settings.  I then have a record that contains 12 of these switch
> setting records corresponding to different tests to be performed.
> I can declare the Global as a record, but when I go to set the fields,
> it does not give me a data type of record to use in declaring the field.
Declare the global as a "variant" - then you can assign anything you want to it.
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
