vrf Number handling?
Question asked by antti.suhonen on Jul 7, 2006
Hi again,
Well, it doesn't for trace vectors but does well with scalars ;D
If the bytes containing the +Infinity are converted to 99E36 (maybe 0-~10 of 'em per trace), the vector data integrity is lost when I swap the bytes based on trigger. Good that we have if/then/elses and "-1.#QNAN" ;D
BTW anyone know why does function 'Coord(x,y)' work? It ain't in the object browser. Are there more of these fancy undocumented gadgets?
BR,
-Antti
  _____
Sent: 07 July 2006 11:08
To: VRF
Subject: RE: [vrf] Number handling?
Hi Corey, rest,
Cheers, that probably fixes it on 7.0. However, I found a workaround; IF max(asReal64(d))>100k OR strPosStr(d, "QNAN")!=-1 Then swap else don't. (Anyone heard of >100kdB? ;D )
Hovering over +Infinity in 6.2, line probe shows "-1.#QNAN" and Alphanumeric +Infinity. What was odd, "QNAN" actually is found in string if array / scalar real number contains them...
BR,
-Antti
  _____
Sent: 06 July 2006 16:56
To: VRF
Hi Antti,
I ran into this problem a couple years back when I upgraded one of our test systems to 7.0.  In the VEE 7.0 program, go to the properties of the main window and set "Convert Infinity to 9.9E37 on Binary Read" to True.  The alphanumerics and line probes will then report these readings as 99E36.
Attached is your example with Convert Infinity set to true.
I submitted this as a defect back in 2004, and I believe it has been fixed in later versions.
Corey
Please note: This e-mail may contain privileged and confidential
information and is intended solely for the addressee. If you are
not the intended recipient or an employee responsible for
delivering this message to the intended recipient, you are
hereby notified that any review, publication, dissemination,
distribution, copying or use of the information in this message
is strictly prohibited. If you have received this e-mail by
error, please notify the sender immediately by replying to the
message and subsequently delete it from your system.
E-mail is susceptible to data corruption, interception,
unauthorized amendment, tampering and viruses. We only send and
receive e-mail messages on the basis that we are not liable for
any such corruption, interception, amendment, tampering,
viruses, any other reprehensible acts or any consequences of
the aforementioned.
