vrf Diference between .net and activex?
Question asked by VRFuser on Mar 6, 2006
> I'm looking for diference between .net and activex in HPVee.
Well technically HP VEE doesn't do .NET - that's Agilent VEE
Assuming that's a typo -
Differences
  They're different object technologies. Completely different.
  To create an ActiveX class object, use CreateOjbect.
  To create a dotNET class instance, use CreateInstance.
Similarities
  Once an object is created, their use looks exactly the same.
  They both use a dot to traverse levels of the hierarchy. Typically,
  this is called a "dot operator", not to be confused with the C++
  scope resolution operator or the PHP "Paamayim Nekudotayim".
One major advantage of 7 is that it has access to .NET COM Interop and can use any COM component. Versions 5 & 6 were only compatible with ActiveX components.
-SHAWN-
To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
leave the subject blank and in the message body put only the word "subscribe"
