An HP ThinkJet, model number HP 2225A, are on the used equipment market for $100 to $200 range and ink cartridges are still available for $15 to $25.
I had one and used it extensively when trying to figure out home some one else's program worked (programmer and source long gone). Very useful way to bug a program and find out what is really going on. Also a lot cheaper then a true GPIB analyzer.
Robert Reavis
Warm Springs Computer Works
----- Original Message -----
To: "VRF" <vrf@agilent.com>
Sent: Tuesday, June 06, 2006 8:55 AM
Subject: RE: [vrf] 9826 Calculator Bus Monitor
>> What you are looking for exists as signals on the HPIB cables.
>> You need a real HPIB bus monitor to do what you want.
> Or considering that you have a 9826, do you also have an HPIB Printer? If
> so, many of them could be set to a "Print All" mode (some setting of the
> address switches). It will then print all the bus traffic. I use to use
> that as a bus monitor when I couldn't get a "real" one. (And the fact
> that
> it printed was better than the real one - since I was interrested in
> command
> sequences, not timing that the real bus monitor gives.)
> ~~Les Hammer
> You are currently subscribed to vrf as: robert@wscw.com
> To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
> with the word subscribe in the message body.
> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
Robert Reavis
> that
> command
> ~~Les Hammer
that as a bus monitor when I couldn't get a "real" one. (And the fact that
it printed was better than the real one - since I was interrested in command
~~Les Hammer
