Stefan,
The sequencer object performs a test of "almost equal" (to quote the help
file) on all pass/fail checks. This means VEE tests out to 6 significant
digits for equality and determine pass of fail based on this. I get the same
result using an IF/THEN/ELSE and the comparison A~=B. The comparison passes
with your two values on A~=B but fails if comparing A==B. A possible
solution to your needs would be to call a new function and return a 1 or 0
and check comparison.
Lyle Carnahan
Technical Consultant
Agilent Technologies
lyle_carnahan@agilent.com
From: s.feuerecker@bebro.de [mailto:s.feuerecker@bebro.de]
Sent: Tuesday, April 17, 2001 12:00 PM
To: vrf@lvld.agilent.com
Subject: vrf Sequencer Failure ??
Hello Vee Users,
i had found an error with the sequencer.
When i compare this value (16777183) with a limit with this value
(16777182) i get a pass. This shouldn't happen.
I use Vee 5.01 on WinNT 4.0 with Sp6a.
You can test this on your machine with the attached file.
When anybody occour this failure too, i will be glad for myself but not for
Agilent Vee.
Thanks for replays
Viele Gre
Best regards
i. A.
Stefan Feuerecker Dipl.Ing. (FH)
Entwicklung Testsysteme
Testing Device Construction
_______________________________________________________
bebro electronic GmbH
Max-Planck-Str. 6-8 - D 72636 Frickenhausen
Tel.: +49 (0) 70 22 - 40 03 - 144 - Fax.: +49 (0) 70 22 - 4 27 72
E-Mail: s.feuerecker@bebro.de - Internet: http://www.bebro.de
(See attached file: sequencer_failure.vee)
To your information:
Ive got the same error on VEE 6.01!
If the number becomes more than 8 digits, the error occur.
Greetings, Alex
Ziehl-Abegg GmbH & Co. KG
Heinz-Ziehl Strae
74653 Knzelsau
Tel.: 07940 16 371
Fax.: 07940 16 117
mailto:Alexander.Lipp@Ziehl-Abegg.de
http://www.Ziehl-Abegg.de
> -----Ursprngliche Nachricht-----
> Von: s.feuerecker@bebro.de [SMTP:s.feuerecker@bebro.de]
> Gesendet am: Dienstag, 17. April 2001 18:00
> An: vrf@lvld.agilent.com
> Betreff: vrf Sequencer Failure ??
> Hello Vee Users,
> for
> Agilent Vee.
> Thanks for replays
> Viele Gre
> Best regards
> i. A.
> (See attached file: sequencer_failure.vee) << Datei: sequencer_failure.vee
