<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=ISO-8859-1"><META content="MSHTML 5.00.2919.6307" name=GENERATOR></HEAD><BODY><DIV><FONT color=#0000ff face=Arial size=2><SPANclass=057483707-15042003>Majed,</SPAN></FONT></DIV><DIV><FONT color=#0000ff face=Arial size=2><SPANclass=057483707-15042003></SPAN></FONT> </DIV><DIV><FONT color=#0000ff face=Arial size=2><SPAN class=057483707-15042003>I getthe same error. I think the relevant error message is the one that appearson the second line in the error box, ie "Values for independent variables mustmatch". That is, your X values of your coords must match in order for acomparison to be made. But I don't know why. This is what the helpsays under "Comparison":</SPAN></FONT></DIV><DIV><FONT color=#0000ff face=Arial size=2><SPANclass=057483707-15042003></SPAN></FONT> </DIV><DIV><FONT color=#0000ff face=Arial size=2><SPAN class=057483707-15042003>"It ispossible for two operands to not be comparable, that is, the two operands arenot less than, greater than, or equal to each other. Examples are Coordswith mismatched mappings and arrays."</SPAN></FONT></DIV><DIV> </DIV><DIV><FONT color=#0000ff face=Arial size=2><SPANclass=057483707-15042003>Yours,</SPAN></FONT></DIV><DIV><FONT color=#0000ff face=Arial size=2><SPAN class=057483707-15042003>WarrenPickles</SPAN></FONT></DIV><DIV> </DIV><BLOCKQUOTE style="MARGIN-RIGHT: 0px"> <DIV align=left class=OutlookMessageHeader dir=ltr><FONT face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> majed.ali@se.abb.com [mailto:majed.ali@se.abb.com]<BR><B>Sent:</B> 15 April 2003 08:24<BR><B>To:</B> VEE vrf<BR><B>Subject:</B> [vrf] Something strange with Coord Data type<BR><BR></DIV></FONT><BR><FONT face=sans-serif size=2>Hi</FONT> <P> <P><FONT face=sans-serif size=2>I want to use if/Then/Else object to compare two values which are coord data type (see the simple attached program). It works fine only when the first component in both values are similar, I get error 416 (Values must have same size and shape) when the first component in both values are different!!</FONT> <P> <P> <P> <P><FONT face=sans-serif size=2>Any feedback would be appreciated.</FONT> <P> <P><FONT face=sans-serif size=2>Best regards</FONT> <P> <P><FONT face=sans-serif size=2>Majed Ali</FONT> <P><FONT face=sans-serif size=2>ABB Corporate Research</FONT> <P><FONT face=sans-serif size=2>majed.ali@se.abb.com</FONT> <P> <P></P></BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@it.lists.it.agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
Bill Ossmann
Philips Ultrasound
e-mail: bill.ossmann@philips.com
To: "VEE vrf" <vrf@it.lists.it.agilent.com>
cc: (bcc: Bill Ossmann/ANR/MS/PHILIPS)
Subject: [vrf] Re: Something strange with Coord Data type
<g.nied@gn-software.de> Classification:
04/15/2003 02:03 AM
Please respond to g.nied
Majed,
use the comparator object instead.
As Warren pointed out, the normal comparison is not possible here.
best regards,
G. Nied
Georg Nied - Software-Development - Hansestr.7 - 51149 Cologne - Germany
Tel: +49 2203 9770915 - Fax: +49 2203 9770924 - eMail:info@gn-software.de
Original Message processed by Tobit InfoCenter
Subject: [vrf] Something strange with Coord Data type (15-Apr-2003 9:24)
To: vrf@it.lists.it.agilent.com
Hi
Best regards
Majed Ali
To: majed.ali@se.abb.com
You are currently subscribed to vrf as: bill.ossmann@philips.com
