I’ll just crawl off and hide under a bush somewhere…
Â
Thank you for that, Les!
Â
Dave
Â
 _____ Â
From: Les Hammer [mailto:Les.Hammer@CompleteTest.com]
Sent: 14 September 2006 17:31
To: VRF
Subject: RE: [vrf] Sequencer bug - wrong file
Â
Â
Â
 >  I have passed the high and low limits in the form of records, so it is easy to import Â
>  (eg. from Excel) and easy to write into the sequencer. However, the sequencer appearsÂ
> to use other (hidden) limits while deciding whether the result is a pass or fail.  Â
> Take a look at the attached example.  Â
Â
I've never used VEE sequencers or records before, but notice that test1 are type "text"
and test2 are Real64. Can the sequencer compare the number -95 with text?
Â
~~Les Hammer
You are currently subscribed to vrf as: watling@icerasemi.com
Â
Â
Dave
Â
 _____ Â
To: VRF
Â
Â
Â
Â
Â
~~Les Hammer
<b><span style='font-weight:bold'>Sent:</span></b> 14 September 2006 17:31
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> RE: [vrf] Sequencer bug -wrong file</span></font><span lang=EN-US><o:p></o:p></span></p></div><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><o:p> </o:p></span></font></p><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'> <o:p></o:p></span></font></p><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></font></p><p class=MsoNormal><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'> > </span></font><fontsize=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>I havepassed the high and low limits in the form of records, so it is easy toimport <font color=blue><span style='color:blue'> </span></font></span></font><o:p></o:p></p><p class=MsoNormal><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>> </span></font><font size=2face=Arial><span style='font-size:10.0pt;font-family:Arial'> (eg. fromExcel) and easy to write into the sequencer. However, the sequencerappears<font color=blue><span style='color:blue'> </span></font></span></font><o:p></o:p></p><p class=MsoNormal><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>></span></font><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'> to use other (hidden) limitswhile deciding whether the result is a pass or fail. <fontcolor=blue><span style='color:blue'> </span></font></span></font><o:p></o:p></p><p class=MsoNormal><font size=2 color=blue face=Arial><span style='font-size:10.0pt;font-family:Arial;color:blue'>></span></font><font size=2 face=Arial><spanstyle='font-size:10.0pt;font-family:Arial'> Take a look at the attachedexample. <font color=blue><span style='color:blue'> </span></font></span></font><o:p></o:p></p><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'> <o:p></o:p></span></font></p><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>I've never used VEE sequencers</span></font> <fontsize=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>or recordsbefore, but notice that test1 are type "text"</span></font><o:p></o:p></p><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>and test2 are Real64. Can the sequencer compare thenumber -95 with text?</span></font><o:p></o:p></p><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'> <o:p></o:p></span></font></p><p class=MsoNormal><font size=2 face=Arial><span style='font-size:10.0pt;font-family:Arial'>~~Les Hammer</span></font><o:p></o:p></p><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'>
To subscribe please send an email to:"vrf-request@lists.it.agilent.com" with the word subscribe in themessage body.
To unsubscribe send a blank email to"leave-vrf@it.lists.it.agilent.com".
"<st1:PersonName w:st="on">owner-vrf@it.lists.it.agilent.com</st1:PersonName>".
Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".<o:p></o:p></span></font></p></div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to<BR>"owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html>
HI DAVID
The attached example appears to be missing requisite libraries.
Stan
Â
Â
~~Les Hammer
