Does anyone have any code written that talks to "Microsofts SQL Server?"
We're trying to migrate from MS Access to SQL Server due to database
corruption issues. I guess SQL Server is designed to recover from errors
much better than Access since it writes data to a temporary location then
finalizes the changes only after checking for errors, or so I've been told.
It also is designed better for multiple users. Access also has some Issues
that will lock everyone out of the database if a certain user (only if he
has different priviledges than everone else) opens the database. Anyones
help would be appreciated.
Rick Hart
Superconductor Technologies
Rick Hart
and Windows NT. We have got the card operational using Active-x and the
Driverlinx direct I/O software. We now want to add more digital I/O (more
Keithley KPCI-PIO96 cards), but are unable to control more than one card at
a time. Keithley customer service is not too VEE friendly. Does anyone
have a VEE example using multiple Keithley digital I/O cards with Active-x
and Driverlinx software? Any help will be much appreciated.
