I wrote an entire application around an Agilent 34970A. I couldn't not
find any off the shelf Panel Drivers so I used plug & play IO. I even
figured out a way to use the RS232 connection instead of having to put a
GPIB card in the computer. If you want to correspond privately about the
techniques I learned during the development of my application please
indicate so on your reply and I will e-mail you.
Mark Behrendt
Darryl Borland wrote:
>Does anyone know of a panel driver for the 34970A DAQ?
>I'm new to VEE my project seems simple. I have to control the DAC (34907A)
>and scan 1 channel on the switch board.
>Darryl Borland
>Vanderbilt University
>Department of Chemistry
>7330 Stevenson Science Center
>Nashville, TN 37235
>Tel:615-322-8171
>Fax:615-343-1234
>You are currently subscribed to vrf as: bricesxroads@attbi.com
>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@it.lists.it.agilent.com".
>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
Mark Behrendt
>Darryl Borland
>Nashville, TN 37235
>Tel:615-322-8171
>Fax:615-343-1234
enable me to ramp the DAC from 0 to 2 VDC. In 100 millivolt steps and holding
for 1 minute after each step.
Im very new to this, approx. 10 hours new.
thanks
Darryl Borland
Nashville, TN 37235
Tel:615-322-8171
Fax:615-343-1234
