Barrie,
How old is the machine in question? Is it running any drivers to fix y2k
problems? I've had problems like yours that were caused when a program reads
the RTC directly instead of getting the current time from the operating
system.
Bill Drago
Test Engineer
L3 Communications - Narda Microwave East
435 Moreland Road
Hauppauge, NY 11788
William.Drago@L-3com.com
631-231-1700 Ext. 572
FAX 631-231-1480
> -----Original Message-----
> From: Barrie Walden [mailto:bwalden@whoi.edu]
> Sent: Friday, January 11, 2002 2:05 PM
> To: Agilent Reflector
> Subject: vrf More on the time zone question
> Hi folks,
> I guess my time zone question is more difficult than I
> thought or few of
> you can duplicate it; I still do not have an answer. Restating the
> problem - displaying the output from Now() in time stamp
> format results
> in a time for a different time zone than the computer is set for. My
> Win2000 machine is set for GMT (and GMT is correctly shown in
> the lower
> right corner) but Vee displays EST. If the Windows settings are
> changed, Vee corrects for this and continues to display EST. Lyle
> suggested looking for an environmental variable such as
> "TIMEZONE" which
> was present under NT but so far I have not found anything
> similar under
> Win2000. There must be a setting somewhere since this
> problem does not
> exist on all machines, if fact it seems to be an issue only on the one
> machine I have where it really counts.
> Any ideas?
> Barrie
> whoi
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.agilent.com".
> Subscriptions and
system.
Bill Drago
Test Engineer
435 Moreland Road
Hauppauge, NY 11788
FAX 631-231-1480
> Hi folks,
> thought or few of
> format results
> the lower
> "TIMEZONE" which
> similar under
> problem does not
> Any ideas?
> Barrie
> whoi
> Subscriptions and
I don't have a definitive answer for the Win2K question, but I found 3
registry entries for "TimeZoneInformation" in
HKEY_LOCAL_MACHINESYSTEMControlSet001, for ControlSet002 and for
CurrentControlSet on my Win2K platform.
Since one of your Win2K machines works properly and the other doesn't, it
might be worthwhile to compare entries for both machines to see if you can
identify a difference.
Good Luck!
George Tyrrell
TestDynamics LLC
----- Original Message -----
To: "Agilent Reflector" <vrf@lvld.agilent.com>
Sent: Friday, January 11, 2002 12:05 PM
> Hi folks,
> I guess my time zone question is more difficult than I thought or few of
> problem - displaying the output from Now() in time stamp format results
> Win2000 machine is set for GMT (and GMT is correctly shown in the lower
> suggested looking for an environmental variable such as "TIMEZONE" which
> was present under NT but so far I have not found anything similar under
> Win2000. There must be a setting somewhere since this problem does not
> Any ideas?
> Barrie
> whoi
