vrf How to retrieve DMM function unit?
Question asked by VRFuser on Sep 7, 2006
Hi, tried to read data as string ("READ TEST x STR"), but the output data is ("None, +14.91").
I've added a "BUS I/O Monitor" as u mentioned, from the  "BUS I/O Monitor" object, the output data vertically appear:
configure:resistance:read? NONE, +14.91 <LF>
My script in "Direct I/O" as below:
WRITE TEXT":CONFigure:RESistance 0"
":WAI INTERNAL:2"
WRITE TEXT":READ?"EOL
READ TEXT x STR
The instrument is connected using GPIB, the small 'k' unit able to appear in DMM primary display, but when the command sent to DMM, my display sometimes will appear 14.91k, sometimes 14.91. Is it something need to do with the DMM register?
Another senerio is when my script stated as below, the function unit 'k' will appear statically with the output data in my display.
WRITE TEXT":CONFigure:CURrent:DC 0"
":WAI INTERNAL:2"
READ TEXT x STR
Thanks for help!
Regards, Jess You
On 9/7/06, Jess You* <HYPERLINK "mailto:youjess@gmail.com"youjess@gmail.com> wrote:
":WAI INTERNAL:2"
READ TEXT x STR
":WAI INTERNAL:2"
READ TEXT x STR
Thanks for help, Mr.FUKUI Yutaka
Regards, Jess You
On 9/7/06, HYPERLINK "mailto:fukui.yutaka@jp.fujitsu.com"
fukui.yutaka@jp.fujitsu.com <HYPERLINK "mailto:fukui.yutaka@jp.fujitsu.com"
fukui.yutaka@jp.fujitsu.com > wrote:
I guess that your DMM outputs data as "14.91kOHM" and "14.91 kOHM".
If your program reads the data as REAL64 ("READ TEXT x REAL64"),
the former data will be "14.91k=14.91E+3" and the latter will be "14.91".
I recommend you to read data as string ("READ TEXT x STR") to check
DMM's output.
Or add a "BUS I/O Monitor" object to the VEE program in order to see the
data on the BUS.
Reagrds,
FUKUI Yutaka
----- Original Message -----
>Date: Thu, 7 Sep 2006 15:30:24 +0800
>From: "Jess You*" <HYPERLINK "mailto:youjess@gmail.com"
youjess@gmail.com>
>To: VRF <HYPERLINK "mailto:vrf@agilent.com"
vrf@agilent.com>
>Subject: [vrf] How to retrieve DMM function unit?
>Hi, i m newbie in VEE Pro, currently doing some testing using VEE Pro and
>instrument DDM (GW iNSTEK, GDM-8246).
>Problem arise during resistance configuration, VEE Pro unable to return the
>function unit 'k' (kOHM), sometimes it appear and sometimes dont [image:
>Crying or Very sad] , e.g. 14.91k instead of 14.91
>How am i get this problem resolve...
>Appreciate for help.
>Regards, Jess
>You are currently subscribed to vrf as: HYPERLINK "mailto:fukui.yutaka@jp.fujitsu.com"
>To subscribe please send an email to: "HYPERLINK "mailto:vrf-request@lists.it.agilent.com"
vrf-request@lists.it.agilent.com " with
the word subscribe in the message body.
>To unsubscribe send a blank email to "HYPERLINK "mailto:leave-vrf@it.lists.it.agilent.com"
leave-vrf@it.lists.it.agilent.com ".
>To send messages to this mailing list,  email "HYPERLINK "mailto:vrf@agilent.com"
vrf@agilent.com ".
>If you need help with the mailing list send a message to
>"HYPERLINK "mailto:owner-vrf@it.lists.it.agilent.com"
owner-vrf@it.lists.it.agilent.com ".
>Search the "unofficial vrf archive" at "HYPERLINK "http://www.oswegosw.com/vrf_archive/"
www.oswegosw.com/vrf_archive/ ".
---  To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
