Additional information about slow file opening:
All vee and vxe programs are on Hard disk drive D: and pictures if there
are any are also on same directory as vee files. Network is not used but it
is configured by default on Compaq Armada E500. I could remove LAN
configuration because we do not need it, but I have not tried it yet.
Seppo Metsala
Test Automation Engineer
Seppo Metsala
does your vee file try to contact any other file (like a picture) which was
originally on a different drive? This kind of halting seems to come from the
operating system when trying to access a file over a network connection -
perhaps using a UNC file name and the server name changed for your local pc.
Hope it helps,
Georg Nied
Software-Development
Hansestr.7 - 51149 Cologne
Germany
Mail: info@gn-software.de
> -----Original Message-----
> From: owner-vrf@lvld.agilent.com [mailto:owner-vrf@lvld.agilent.com]On
> Behalf Of Seppo Metsala
> Sent: Wednesday, March 20, 2002 9:21 AM
> To: vrf@lvld.agilent.com
> Cc: timo.kaipainen@mil.fi
> Subject: vrf slow file opening
> Hi all
> Can anyone help me with this problem.
> When opening vxe (or vee) file it sometimes waits for about 20-30seconds.
> After that it runs normally. No error messages whatsoever. The
> window opens
> at once but the bar indicating loading stops at about 100% and nothing
> happens. It does not happen every time you open this file and
> there is not
> anything wrong with vee files. Files have worked fine with our old PC.
> The problem started when we moved files to new computer. Old was
> AST 233MMX
> laptop and new one is Compaq Armada E500 1000MHz laptop. We use Ines
> GPIB-card. We tried new BIOS for computer, no affect. Taskinfo program
> shows minimal vee loading at the time of halting. Compaq support does not
> have any knowledge about this kind of halting.
> How should I proceed?
> Any ideas appreciated
> Seppo Metsala
