----- Original Message -----
From: "Ashley Derrick" <ashley@smartsolutions.karoo.co.uk>
To: "VRF" <vrf@agilent.com>
Sent: Saturday, November 15, 2003 12:45 AM
Subject: [vrf] Fw: RE: High baud rate RS232- MSCOMM
> Hi again,
> I have managed to obtain and load MSCOMM and import the ActiveX functions
> to VEE OK. Does anyone have an example please. I guess I should really buy
> the Microsoft book but a simple example would be a nice starter.
> Kind regards,
> Ashley.
> From: "Shawn Fessenden" <shawn@testech-ltd.com>
> Sent: Thursday, November 13, 2003 9:50 PM
> Subject: [vrf] RE: High baud rate RS232
> > > I kick myself for not trying it before.
> > I feel the same way - I played with the whole setup for way too long
> before
> > I figured out how to make it run right.
> > > I have no knowlege of MSCOMM.
> > This is the standard serial communication ActtiveX control from
Microsoft.
> > If you have any MS languages installed you have it. Look for "Microsoft
> Comm
> > Control x.x" in Device->ActiveX Control References... It's very easy to
> use.
> > Use the Settings property to set baud rate, parity, data and stop bits,
> use
> > the Handshaking property to set handshaking, then set the PortOpen
> property
> > to True and you're all set. To output stuff, set the Output property and
> to
> > input stuff get the Input property.
> > -SHAWN-
> > You are currently subscribed to vrf as:
> > To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
> > To unsubscribe send a blank email to
> > To send messages to this mailing list, email "vrf@agilent.com".
> > If you need help with the mailing list send a message to
> You are currently subscribed to vrf as: ashley@smartsolutions.karoo.co.uk
to VEE OK. Does anyone havea an example please. I guess I should really buy
Kind regards,
Ashley.
before
> This is the standard serial communication ActtiveX control from Microsoft.
Comm
use.
use
property
to
> -SHAWN-
