Yohan,
you should also check the showpanel and hidepanel functions, and uncheck the PopOnExecute property of the panel, that gives you more flexibility as of how and when you will show the panel to the user.
Nelson
Doug Parrish wrote:
> Yohan,
> I think what you want to do is add a "confirm OK" to the output
> sequence pin of the last object to execute in your user object. Do not
> add it to your user panel. That should keep it from closing on you.
> -Doug
> -----Original Message-----
> From: Yohan Belval [mailto:yohan_belval@hotmail.com]
> Sent: Tuesday, September 26, 2006 3:50 PM
> To: VRF
> Subject: [vrf] User Object Panel
> Hi,
> I'm stuck with a problem. I'm building an application that calls a
> "user object" to display data. I pop up the "user object" panel to
> display this data. But when it is done processing and displaying, it
> automatically closes the "user object" panel. I want to be able for
> this to stay open, even if its not active while my application is
> running. Sort of like a floating window that I could minimize and
> keep on doing other stuff.
> Thanks!
> Yohan
> You are currently subscribed to vrf as: doug.parrish@comtechpst.com To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com"
> with the word subscribe in the message body.
> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
> You are currently subscribed to vrf as: nmambre@seebeck.com.ve To
> subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
Nelson
Doug Parrish wrote:
> Yohan,
> -Doug
> To: VRF
> Hi,
> Thanks!
> Yohan
can be used to control the display of the panel
Sent: Tuesday, September 26, 2006 12:50 PM
To: VRF
running. Sort of like a floating window that I could minimize and keep
Thanks!
Yohan
You are currently subscribed to vrf as: RPratt@symmetricom.com To
