> I have a INIT:CONT OFF in the program, and also have INIT:IMM at the end of the program.
Â
Are you sending the next INIT:IMM before the previous sweep has finished? Try putting in a 10mS delay.
Les Hammer
VP of Engineering
Smart Sensor Systems
720 14th Street SW
Loveland, CO. 80537-6349
Les.Hammer@SmartSensorSystems.com
Les.Hammer@CompleteTest.com
Â
Les Hammer
VP of Engineering
720 14th Street SW
The problem is that the trigger system was not in the idle state. The most likely cause is that you have continuous sweep enabled. Since this is a SCPI Instrument, the easiest thing to do is to send the command
INIT:CONT OFF;ABORt  which will disable continuous triggering and place the trigger system into the idle state.
Â
Then when an INIT is sent, a single measurement sequence will occur.
Jay Nemeth-JohannesÂ
Smart Sensor SystemsÂ
720 SW 14th Street
Loveland, Colorado 80537
(970) 663-0006Â (Office)
(970) 290-9797 (Cell)
HYPERLINK "http://www.smartsensorsystems.com/"www.SmartSensorSystems.com
Â
 _____ Â
Sent: Friday, August 18, 2006 12:49 PM
To: VRF
Subject: [vrf] a simple question, need help from VEE experts.
I am trying to sweep a power level with fix frequency using Agilent E8247C PSG CW Signal Generator.
When I ran my VEE program, I got an error “Init ignored†on the Generator and the output power level has no change at all (reading from the connected Spectrum Analyzer.
Â
Any help, highly appreciated.
You are currently subscribed to vrf as: jay.johannes@completetest.com
