Vinod
I haven't noticed that before. I would say it's a BUG.
/Alex
Sent: den 29 augusti 2006 15:09
To: VRF
Subject: RE: [vrf] Record array with Enum values ???
Alex,
Yes, I have seen that. Even the "Unbuild Record" object also fails! I am not sure if this would qualify as a BUG???
-Vinod
--- "Alexander Poulikakos (KI/EAB)" <alexander.poulikakos@ericsson.com>
wrote:
> Hi
> When using the "Rec.fieldA" notation on record arrays, I assume that
> internally somewhere in VEE, all Record fields are concatenated and
> then returned as an array. At least that's how it works for all data
> types except for ENUM.
> For ENUMs, I would expect this kind of behavior. See attached example
> (EnumToArray.vee), where ENUMs are concatenated to a TEXT array.
> I guess there's no workaround for this, except for looping through the
> array and converting ENUMs to TEXT.
> /Alex
> From: Vinod [mailto:papineni_vinod@yahoo.com]
> Sent: den 29 augusti 2006 04:31
> To: VRF
> Subject: Re: [vrf] Record array with Enum values ???
> Is this because you cannot have an array of ENUM?
> wrote:
> > Hi VRF
> > When having a record array, it is possible to use "Rec.FieldA" to
> > retrieve "FieldA" from all elements in the array (the return value
> > is then an array it self with all the record field values), without
> > looping through the entire array. But for some reason it's not
> > possible to do this if the record field is of ENUM type. See
> > attached example "RecArray_WithEnum.vee".
> > Is there some sort of workaround for this, without looping through
> > the
> > entire array? I only need the selected value from each ENUM (Not the
> > entire ENUM) .
> > Regards,
> > Alex
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
You are currently subscribed to vrf as:
alexander.poulikakos@ericsson.com To subscribe please send an email to:
"vrf-request@lists.it.agilent.com" with the word subscribe in the message body.
/Alex
To: VRF
Alex,
-Vinod
wrote:
> Hi
> /Alex
> To: VRF
> wrote:
> > Hi VRF
> > the
> > entire ENUM) .
> > Regards,
> > Alex
Do You Yahoo!?
